跳转到主内容
Teddy Ruxpin Mouth Replacement
你所需要的
  1. Teddy Ruxpin Mouth Replacement, Battery: 步骤 1 中的图像 1,2 Teddy Ruxpin Mouth Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the vest covering the back of the bear.
    • Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
    • Captured screws will stay in place, no need to worry about losing this one!
  2. Teddy Ruxpin Mouth Replacement: 步骤 2 中的图像 1,1
    • Pull the tab outward to remove the protective plate for the batteries.
  3. Teddy Ruxpin Mouth Replacement: 步骤 3 中的图像 1,1
    • Remove all four AA batteries by pushing the positive end down and pulling the battery out toward yourself.
  4. Teddy Ruxpin Mouth Replacement, Arms: 步骤 4 中的图像 1,3 Teddy Ruxpin Mouth Replacement, Arms: 步骤 4 中的图像 2,3 Teddy Ruxpin Mouth Replacement, Arms: 步骤 4 中的图像 3,3
    • Cut the orange shirt and zip tie.
    • Remove the zip tie.
  5. Teddy Ruxpin Mouth Replacement: 步骤 5 中的图像 1,1
    • Cut across the back seam of the head of the bear along the arrow.
    • This damages the bear's exterior and will require resewing.
  6. Teddy Ruxpin Mouth Replacement: 步骤 6 中的图像 1,3 Teddy Ruxpin Mouth Replacement: 步骤 6 中的图像 2,3 Teddy Ruxpin Mouth Replacement: 步骤 6 中的图像 3,3
    • Remove the interior of the doll.
    • Peel the outer layer around the head of the bear and forcefully pry off the face of the bear from the outside layer of the bear.
    • This will be difficult and require significant force, but do not fear about breaking the doll at this stage.
  7. Teddy Ruxpin Mouth Replacement: 步骤 7 中的图像 1,2 Teddy Ruxpin Mouth Replacement: 步骤 7 中的图像 2,2
    • Extract each arm button.
    • Pull on the stuffing of the bear and not the wire to remove the arm button.
  8. Teddy Ruxpin Mouth Replacement: 步骤 8 中的图像 1,2 Teddy Ruxpin Mouth Replacement: 步骤 8 中的图像 2,2
    • Pull off the rest of the outside layer of the bear.
  9. Teddy Ruxpin Mouth Replacement: 步骤 9 中的图像 1,1
    • Unplug the arms from the main body.
  10. Teddy Ruxpin Mouth Replacement, Housing Cover: 步骤 10 中的图像 1,3 Teddy Ruxpin Mouth Replacement, Housing Cover: 步骤 10 中的图像 2,3 Teddy Ruxpin Mouth Replacement, Housing Cover: 步骤 10 中的图像 3,3
    • Unscrew the eleven circled 12.5mm Phillips #1 screws.
    • Remove the top of the housing to access the electronics inside.
  11. Teddy Ruxpin Mouth Replacement, Eyes: 步骤 11 中的图像 1,1
    • Using a Phillips #1 screwdriver, remove the two 12.5mm screws connecting the eyes to the rest of the mechanism.
  12. Teddy Ruxpin Mouth Replacement: 步骤 12 中的图像 1,2 Teddy Ruxpin Mouth Replacement: 步骤 12 中的图像 2,2
    • Unplug the two sets of wires connected to the back of the eyes by using moderate to high force.
  13. Teddy Ruxpin Mouth Replacement: 步骤 13 中的图像 1,1
    • Once those wires are disconnected, desolder the wires connected from the eye motherboard.
  14. Teddy Ruxpin Mouth Replacement, Mouth: 步骤 14 中的图像 1,2 Teddy Ruxpin Mouth Replacement, Mouth: 步骤 14 中的图像 2,2
    • Remove five 12.5mm Phillips #1 screws.
    • Pull the mouth mechanism out of the shell.
  15. Teddy Ruxpin Mouth Replacement: 步骤 15 中的图像 1,2 Teddy Ruxpin Mouth Replacement: 步骤 15 中的图像 2,2
    • Unscrew the last 12.5mm Phillips #1 screw holding the mouth together
    • Open the mouth mechanism
结论
Jayin Patel
于01/23/20注册
406 声望
创作了4篇指南
团队
Cal Poly, Team S18-G5, White Winter 2020 Cal Poly, Team S18-G5, White Winter 2020 的会员
CPSU-WHITE-W20S18G5
4 名成员
创作了7篇指南
3条评论
His mouth and nose fell out leaving a hole in his face. How do i fix it or is the repair shop local? He is 30 years old.
rrhall559 - 回复
Mouth and nose fellout
rrhall559 - 回复
World of wonder made it and they aren’t in business anymore
rrhall559 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 1,323
