简介
If your Teddy Ruxpin’s mouth is not moving correctly or seems like it is malfunctioning, this replacement guide will help you fix your Teddy Ruxpin. The mouth should move along with storytime as audio is playing through the speaker. This guide will include desoldering and unscrewing, so be sure to utilize the iFixit desoldering guide while replacing this part as well as the other prerequisite guides.
你所需要的
Remove the vest covering the back of the bear.
Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
Unscrew the eleven circled 12.5mm Phillips #1 screws.
Remove the top of the housing to access the electronics inside.
Using a Phillips #1 screwdriver, remove the two 12.5mm screws connecting the eyes to the rest of the mechanism.
