跳转到主内容
Tagital T7X Speaker Replacement
你所需要的
  1. Tagital T7X Speaker Replacement, Case: 步骤 1 中的图像 1,3 Tagital T7X Speaker Replacement, Case: 步骤 1 中的图像 2,3 Tagital T7X Speaker Replacement, Case: 步骤 1 中的图像 3,3
    • Place the Tagital T7X on a sturdy surface.
    • Insert the plastic opening tool into the crack and pry open the tablet. Move the tool along the edge, while continuing to pry up the casing.
  2. Tagital T7X Speaker Replacement, Speaker: 步骤 2 中的图像 1,3 Tagital T7X Speaker Replacement, Speaker: 步骤 2 中的图像 2,3 Tagital T7X Speaker Replacement, Speaker: 步骤 2 中的图像 3,3
    • Remove the ribbon cable on the top left corner of the mother board.
    • Gently lift the black tape up to see the ribbon cable socket.
  3. Tagital T7X Speaker Replacement: 步骤 3 中的图像 1,3 Tagital T7X Speaker Replacement: 步骤 3 中的图像 2,3 Tagital T7X Speaker Replacement: 步骤 3 中的图像 3,3
    • Push both side buttons away from the socket by using a spudger.
  4. Tagital T7X Speaker Replacement: 步骤 4 中的图像 1,2 Tagital T7X Speaker Replacement: 步骤 4 中的图像 2,2
    • Gently pull the ribbon cable away from the socket.
    • Don't be afraid to use some force for this step.
  5. Tagital T7X Speaker Replacement: 步骤 5 中的图像 1,2 Tagital T7X Speaker Replacement: 步骤 5 中的图像 2,2
    • The soldering iron can destroy components on the motherboard. Only touch the soldering iron to the solder already on the board.
    • Touch the tip of the soldering iron to the solder connecting the positive (red) wire.
    • Pull back on the wire with the iron in place, removing it from the hot solder.
    • Repeat this step for the negative wire.
    • The solder will be melted almost instantly. There is no need to hold the iron on the solder for than a second or two. Visit IFixit's soldering guide for more info.
  6. Tagital T7X Speaker Replacement: 步骤 6 中的图像 1,2 Tagital T7X Speaker Replacement: 步骤 6 中的图像 2,2
    • Remove the speaker from the motherboard.
结论
另外一个人完成了本指南。
Hanlong Chen
于02/10/16注册
265 声望
创作了2篇指南
团队
USF Tampa, Team 2-1, Sullivan Spring 2016 USF Tampa, Team 2-1, Sullivan Spring 2016 的会员
USFT-SULLIVAN-S16S2G1
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 225
