简介
If you need to replace the speakers in the TMY V08, the replacement process can be found in this guide. The speaker may need to be replaced if the sound produced is muffled, or no sound is produced at all. If any of these issues apply to your device, refer to our troubleshooting guide.
In order to keep the motherboard safe, before beginning the replacement, make sure the TMY V08 is on a solid surface. Also make sure the TMY V08 is away from non-hardwood flooring and carpets. This will reduce the risk of static electric shocks that may damage the circuit or other components.
你所需要的
Turn the projector upside-down.
Remove the six 10.8 mm screws from the bottom of the projector using a Phillips #1 screwdriver.
Turn the projector back over and lift the top casing panel off the projector.
Remove the four 6.4 mm screws from the motherboard using a Phillips #1 screwdriver.
Pull back the motherboard to expose the connectors underneath.
