跳转到主内容
TDK Life on Record Trek Max A34 Small Speaker Replacement
你所需要的
  1. TDK Life on Record Trek Max A34 Small Speaker Replacement, Small Speaker: 步骤 1 中的图像 1,2 TDK Life on Record Trek Max A34 Small Speaker Replacement, Small Speaker: 步骤 1 中的图像 2,2
    • Use a TR7 screwdriver to remove the screws from the battery cover located on the underside of the device.
    • Remove the battery cover.
  2. TDK Life on Record Trek Max A34 Small Speaker Replacement: 步骤 2 中的图像 1,2 TDK Life on Record Trek Max A34 Small Speaker Replacement: 步骤 2 中的图像 2,2
    • Unplug and remove the battery.
    • Use a metal spudger to pry off the rubber padding.
  3. TDK Life on Record Trek Max A34 Small Speaker Replacement: 步骤 3 中的图像 1,3 TDK Life on Record Trek Max A34 Small Speaker Replacement: 步骤 3 中的图像 2,3 TDK Life on Record Trek Max A34 Small Speaker Replacement: 步骤 3 中的图像 3,3
    • Use a J00 screwdriver to unscrew the screws that are under the rubber pads.
    • Remove the battery holder and be sure to thread the wires through the hole within the part.
  4. TDK Life on Record Trek Max A34 Small Speaker Replacement: 步骤 4 中的图像 1,3 TDK Life on Record Trek Max A34 Small Speaker Replacement: 步骤 4 中的图像 2,3 TDK Life on Record Trek Max A34 Small Speaker Replacement: 步骤 4 中的图像 3,3
    • Use a metal spudger to pry off the front and back mesh screens.
    • You may need to move the metal spudger along the edge of the screen to remove it easier.
  5. TDK Life on Record Trek Max A34 Small Speaker Replacement: 步骤 5 中的图像 1,3 TDK Life on Record Trek Max A34 Small Speaker Replacement: 步骤 5 中的图像 2,3 TDK Life on Record Trek Max A34 Small Speaker Replacement: 步骤 5 中的图像 3,3
    • Use the a metal spudger to pry up the rubber cover on the top surface of the device.
    • Peel off the rubber cover to reveal the buttons and screws underneath.
  6. TDK Life on Record Trek Max A34 Small Speaker Replacement: 步骤 6 中的图像 1,2 TDK Life on Record Trek Max A34 Small Speaker Replacement: 步骤 6 中的图像 2,2
    • Use a J00 screwdriver to unscrew the screws that hold the top cover in place.
    • Remove the top cover.
  7. TDK Life on Record Trek Max A34 Small Speaker Replacement: 步骤 7 中的图像 1,2 TDK Life on Record Trek Max A34 Small Speaker Replacement: 步骤 7 中的图像 2,2
    • On the backside of the device, unscrew the case screws with a J00 screwdriver.
    • Only the screws on the backside are needed to hold the frame together, do not remove screws on the front.
    • Once the screws are removed, separate the two frame pieces.
  8. TDK Life on Record Trek Max A34 Small Speaker Replacement: 步骤 8 中的图像 1,3 TDK Life on Record Trek Max A34 Small Speaker Replacement: 步骤 8 中的图像 2,3 TDK Life on Record Trek Max A34 Small Speaker Replacement: 步骤 8 中的图像 3,3
    • The following steps can be applied to either the left or the right speaker.
    • Use a J00 screwdriver to unscrew the four screws that secure the speaker.
    • The speaker should fall out naturally. If the speaker is stuck, use a plastic opening tool or a metal spudger to gently lift it out.
    • Desolder the black and red speaker wires.
    • Review the Desolder guide if you are unfamiliar with soldering.
结论
另外一个人完成了本指南。
Mario Lazaga
于01/14/19注册
1 声望
创作了2篇指南
团队
IUPUI, Team S3-G3, Wilson Spring 2019 IUPUI, Team S3-G3, Wilson Spring 2019 的会员
IUPUI-WILSON-S19S3G3
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 18
总计 361
