跳转到主内容
System x3650 CPU and Memory Replacement
你所需要的
  1. System x3650 CPU and Memory Replacement, CPU and Memory: 步骤 1 中的图像 1,2 System x3650 CPU and Memory Replacement, CPU and Memory: 步骤 1 中的图像 2,2
    • Make sure that you have unplugged the power cable before servicing.
    • Pull the latch on the top cover up.
    • Slide the cover out.
  2. System x3650 CPU and Memory Replacement: 步骤 2 中的图像 1,3 System x3650 CPU and Memory Replacement: 步骤 2 中的图像 2,3 System x3650 CPU and Memory Replacement: 步骤 2 中的图像 3,3
    • Press the two latches on the riser card assembly, indicated by blue arrows and outlines.
    • Slowly take the the riser card assembly out.
    • Doing so will allow you to remove the white plastic airflow guides.
    • This will provide access to the computer parts that you want to replace.
  3. System x3650 CPU and Memory Replacement: 步骤 3 中的图像 1,1
    • Move the heat sink bracket lever to the open position and remove the heat sink.
    • This will provide access to the processor.
  4. System x3650 CPU and Memory Replacement: 步骤 4 中的图像 1,2 System x3650 CPU and Memory Replacement: 步骤 4 中的图像 2,2
    • Open the CPU retention bracket lever.
    • Remove the old processor from the socket.
  5. System x3650 CPU and Memory Replacement: 步骤 5 中的图像 1,2 System x3650 CPU and Memory Replacement: 步骤 5 中的图像 2,2
    • Remove the old RAM if it is being replaced.
    • Unfasten the clamps on both ends of the slot.
    • Take out the memory module.
  6. System x3650 CPU and Memory Replacement: 步骤 6 中的图像 1,2 System x3650 CPU and Memory Replacement: 步骤 6 中的图像 2,2
    • Insert the new memory modules into the empty RAM slots securely.
    • The clamps on both ends of the slot should click into place.
    • See this link for the DIMM installation sequence.
  7. System x3650 CPU and Memory Replacement: 步骤 7 中的图像 1,3 System x3650 CPU and Memory Replacement: 步骤 7 中的图像 2,3 System x3650 CPU and Memory Replacement: 步骤 7 中的图像 3,3
    • Insert new CPU into socket.
    • Ensure that the CPU chip is positioned correctly (i.e. its marked corner is facing bottom left).
    • Apply thermal paste to the top of the processor if necessary.
    • Close the CPU retention bracket lever.
    • An insecure or improper placement can damage a CPU or the socket pinout.
  8. System x3650 CPU and Memory Replacement: 步骤 8 中的图像 1,1
    • Place the heat sink on top of the CPU.
    • Move the heat sink bracket lever to closed position.
  9. System x3650 CPU and Memory Replacement: 步骤 9 中的图像 1,3 System x3650 CPU and Memory Replacement: 步骤 9 中的图像 2,3 System x3650 CPU and Memory Replacement: 步骤 9 中的图像 3,3
    • If you need to add a second processor, move the heat sink bracket lever to open position.
    • Take out the white plastic cover on the second socket.
    • Repeat steps 7 and 8 for the second CPU/socket (insert a CPU and a heat sink).
  10. System x3650 CPU and Memory Replacement: 步骤 10 中的图像 1,3 System x3650 CPU and Memory Replacement: 步骤 10 中的图像 2,3 System x3650 CPU and Memory Replacement: 步骤 10 中的图像 3,3
    • Insert the plastic airflow guides back in their places.
    • Insert the riser card assembly, pushing it into its slot.
  11. System x3650 CPU and Memory Replacement: 步骤 11 中的图像 1,2 System x3650 CPU and Memory Replacement: 步骤 11 中的图像 2,2
    • Slide the top cover in place firmly.
    • Ensure that the latch is in the down position.
结论
Follow this guide to replace or upgrade CPU and memory on IBM System x3650. Up to 2 processors can be installed. Up to 48 GB of RAM can be installed.
Serguei Potechnykh
于09/16/20注册
193 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 16
过去 30 天: 48
总计 3,013
