跳转到主内容
Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement
你所需要的
  1. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Case: 步骤 1 中的图像 1,3 Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Case: 步骤 1 中的图像 2,3 Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Case: 步骤 1 中的图像 3,3
    • Use the Phillips #0 to remove the screw located on the back of the camera above the mount.
    • Slide the mount out from the bottom of the device.
  2. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: 步骤 2 中的图像 1,1
    • Remove the back of the case by placing a iFixit opening tool underneath the edge of the case and prying it up.
  3. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the back of the case without pulling the cables connected to the motherboard and the speaker on the back of the case.
  4. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Motion Sensor: 步骤 4 中的图像 1,3 Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Motion Sensor: 步骤 4 中的图像 2,3 Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Motion Sensor: 步骤 4 中的图像 3,3
    • Facing the inside of the front of the case, release the white ribbon cable by pulling the black rectangular connector at the end of the connection
    • Once the black holder is opened, gently pull the cable out of the holder.
  5. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: 步骤 5 中的图像 1,1
    • Facing the back of the small board, remove the two 2.0 mm Phillips #0 black screws that connect it to the back of the case.
  6. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: 步骤 6 中的图像 1,1
    • Carefully use a soldering iron to melt the solder in three places that connect the motion sensor. For more information on soldering follow this helpful guide.
    • Pull the sensor out from the motherboard.
结论
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 604
