Does your surfboard have a broken or loose fin? This guide will help you replace your surfboard fin to get you back on the water in no time!
With your new or repaired fin, insert the back in first so that you feel the inlet on the fin clip into the little rod in the slit.
Once you feel the back secure, bring the front of the fin down into the slit.
Place the screw back into the hole and begin turning clockwise using the key.
Continue turning until the screw is tight and won't turn any more.
Once the screw stops turning, do not continue to tighten or you may damage the screw or fin.
Make sure the screw can no longer be seen.
Wiggle your fin gently to test for looseness, and you have successfully replaced your surfboard fin.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
