当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Lay your surfboard down on a flat, durable surface long enough to support the length of your board.
Make sure the small screw hole in front of the fin is free of debris and sand.
Insert the key into the hole and begin turning counter-clockwise to loosen the screw inside.
Continue turning counter-clockwise until the screw is free.
Firmly grasp the fin with one hand and place your other hand on the surfboard for stabilization.
Simultaneously lift the fin while tilting it backwards to remove the fin.
Notice the circular inlet on the rear bottom side of the fin. This inlet of the fin fits snuggly into the little rod located in the back of the fin slit on the board, much like a puzzle.
With your new or repaired fin, insert the back in first so that you feel the inlet on the fin clip into the little rod in the slit.
Once you feel the back secure, bring the front of the fin down into the slit.
Place the screw back into the hole and begin turning clockwise using the key.
Continue turning until the screw is tight and won't turn any more.
Once the screw stops turning, do not continue to tighten or you may damage the screw or fin.
Make sure the screw can no longer be seen.
Wiggle your fin gently to test for looseness, and you have successfully replaced your surfboard fin.
取消:我没有完成这个指南。
2等其他人完成本指南。
与3其他贡献者
于09/29/15注册
165 声望
撰写一个指南
徽章: 5
+ 2更多徽章
CPSU-GREEN-F15S10G3
4 名成员
创作了4篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 33
总计 4,432
