跳转到主内容
Supersonic Matrix SC-91MID Speakers Replacement
你所需要的
  1. Supersonic Matrix SC-91MID Speakers Replacement, Back cover: 步骤 1 中的图像 1,1
    • Use an opening tool to separate the back cover of the tablet by wedging the tool into the crease between the back cover and touchscreen.
    • Work your way around the perimeter of the tablet to detach the back cover and remove it carefully so you don't rip any cables attached.
  2. Supersonic Matrix SC-91MID Speakers Replacement: 步骤 2 中的图像 1,1
    • Use a spudger to carefully disconnect the display ribbons from the motherboard.
  3. Supersonic Matrix SC-91MID Speakers Replacement: 步骤 3 中的图像 1,1
    • To remove the battery, use the spudger to pry the battery up and away from the tablet.
    • You might have some difficulty removing due to glue holding the battery in place.
    • Work your way around the perimeter of the battery with the spudger or opening picks gently so you don't bend or puncture the battery.
  4. Supersonic Matrix SC-91MID Speakers Replacement: 步骤 4 中的图像 1,2 Supersonic Matrix SC-91MID Speakers Replacement: 步骤 4 中的图像 2,2
    • Use a spudger to remove the speakers.
    • To remove the motherboard, remove the three screws that hold the board in place with a Phillips screwdriver.
  5. Supersonic Matrix SC-91MID Speakers Replacement, Speakers: 步骤 5 中的图像 1,1
    • Desolder the four speaker wires connecting the speaker to the motherboard using a soldering station.
    • If you're unfamiliar with soldering or desoldering check out this guide 如何焊接和拆焊
    • Be sure to wear protective eye wear. Also, keep in mind that the soldering iron will become extremely hot.
    • The tool in the picture is not required for this step. It is just being used to point out the wires.
结论
另外一个人完成了本指南。
Andrew Osborn
于03/21/17注册
134 声望
撰写一个指南
团队
Texas Tech, Team S46-G4, Bennett Spring 2017 Texas Tech, Team S46-G4, Bennett Spring 2017 的会员
TTU-BENNETT-S17S46G4
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 10
总计 198
