跳转到主内容
加入维修社区 - 创建账户
SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement
你所需要的
  1. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Wedge the plastic opening tool between the back cover of the device and the front panel.
    • You will hear a snapping sound as the cover is separated from the body of the device.
    询问修复机器人
    添加评论
  2. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: 步骤 2 中的图像 1,1
    • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
    • Again, you will hear a snapping sound as the cover is separated from the body of the device.
    询问修复机器人
    添加评论
  3. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: 步骤 3 中的图像 1,2 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: 步骤 3 中的图像 2,2
    • Lift the back cover from the body of the device to expose the internal components.
    询问修复机器人
    添加评论
  4. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement, Battery: 步骤 4 中的图像 1,3 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement, Battery: 步骤 4 中的图像 2,3 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement, Battery: 步骤 4 中的图像 3,3
    • Remove the Battery
    • The battery is secured to the back panel with tape and glue.
    • Peel back the tape around the battery and discard it.
    • Tear through the adhesive holding the battery by using the spudger tool.
    询问修复机器人
    添加评论
  5. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: 步骤 5 中的图像 1,3 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: 步骤 5 中的图像 2,3 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: 步骤 5 中的图像 3,3
    • Desolder the 2 Battery Wires
    • The Battery has two wires connected to the motherboard (one black and one red).
    • If you're unfamiliar with soldering or desoldering check out this guide.
    • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so make sure you are aware of your surroundings.
    添加评论
  6. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement, Rear Facing Camera: 步骤 6 中的图像 1,2 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement, Rear Facing Camera: 步骤 6 中的图像 2,2
    • Remove the two Phillips #00 screws attaching the housing of the camera to the device.
    询问修复机器人
    添加评论
  7. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: 步骤 7 中的图像 1,1
    • With the screws removed you should easily be able to remove the camera unit.
    询问修复机器人
    添加评论
  8. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: 步骤 8 中的图像 1,2 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: 步骤 8 中的图像 2,2
    • Follow the camera unit back to the motherboard.
    • Use the spudger tool to remove the camera.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Dr Shaverz boyz Dr Shaverz boyz 的会员
Community
3 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 442
