跳转到主内容
SuperSonic Matrix Mid SC-999 Microphone Replacement
你所需要的
  1. SuperSonic Matrix Mid SC-999 Microphone Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Wedge the plastic opening tool between the back cover of the device and the front panel.
    • You will hear a snapping sound as the cover is separated from the body of the device.
  2. SuperSonic Matrix Mid SC-999 Microphone Replacement: 步骤 2 中的图像 1,1
    • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
    • Again, you will hear a snapping sound as the cover is separated from the body of the device.
  3. SuperSonic Matrix Mid SC-999 Microphone Replacement: 步骤 3 中的图像 1,2 SuperSonic Matrix Mid SC-999 Microphone Replacement: 步骤 3 中的图像 2,2
    • Lift the back cover from the body of the device to expose the internal components.
  4. SuperSonic Matrix Mid SC-999 Microphone Replacement, Microphone: 步骤 4 中的图像 1,1
    • Remove the microphone from its compartment.
    • The microphone is located toward the bottom left corner of the device (assuming the speakers are located on the right side of you).
  5. SuperSonic Matrix Mid SC-999 Microphone Replacement: 步骤 5 中的图像 1,2 SuperSonic Matrix Mid SC-999 Microphone Replacement: 步骤 5 中的图像 2,2
    • Use the soldering iron to remove the wires connected to the microphone.
    • If you're unfamiliar with soldering or desoldering, check out this guide.
    • Be sure to wear protective eye wear. Also, keep in mind that the soldering iron will become extremely hot.
结论
Harris Dagha
于03/26/15注册
866 声望
创作了7篇指南
团队
Dr Shaverz boyz Dr Shaverz boyz 的会员
Community
3 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 224
