跳转到主内容
加入维修社区 - 创建账户
SuperSonic Matrix Mid SC-999 LCD Replacement
你所需要的
    1. SuperSonic Matrix Mid SC-999 LCD Replacement, Back Cover: 步骤 1 中的图像 1,1
      • Wedge the plastic opening tool between the back cover of the device and the front panel.
      • You will hear a snapping sound as the cover is separated from the body of the device.
      询问修复机器人
      添加评论
    2. SuperSonic Matrix Mid SC-999 LCD Replacement: 步骤 2 中的图像 1,1
      • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
      • Again, you will hear a snapping sound as the cover is separated from the body of the device.
      询问修复机器人
      添加评论
    3. SuperSonic Matrix Mid SC-999 LCD Replacement: 步骤 3 中的图像 1,2 SuperSonic Matrix Mid SC-999 LCD Replacement: 步骤 3 中的图像 2,2
      • Lift the back cover from the body of the device to expose the internal components.
      询问修复机器人
      添加评论
    1. SuperSonic Matrix Mid SC-999 LCD Replacement, Battery: 步骤 4 中的图像 1,3 SuperSonic Matrix Mid SC-999 LCD Replacement, Battery: 步骤 4 中的图像 2,3 SuperSonic Matrix Mid SC-999 LCD Replacement, Battery: 步骤 4 中的图像 3,3
      • Remove the Battery
      • The battery is secured to the back panel with tape and glue.
      • Peel back the tape around the battery and discard it.
      • Tear through the adhesive holding the battery by using the spudger tool.
      询问修复机器人
      添加评论
    2. SuperSonic Matrix Mid SC-999 LCD Replacement: 步骤 5 中的图像 1,3 SuperSonic Matrix Mid SC-999 LCD Replacement: 步骤 5 中的图像 2,3 SuperSonic Matrix Mid SC-999 LCD Replacement: 步骤 5 中的图像 3,3
      • Desolder the 2 Battery Wires
      • The Battery has two wires connected to the motherboard (one black and one red).
      • If you're unfamiliar with soldering or desoldering check out this guide.
      • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so make sure you are aware of your surroundings.
      添加评论
    1. SuperSonic Matrix Mid SC-999 LCD Replacement, Speaker: 步骤 6 中的图像 1,1
      在这个步骤中使用的工具:
      • Remove the Speakers
      • Use the tweezers to remove the speakers from their compartments.
      添加评论
    2. SuperSonic Matrix Mid SC-999 LCD Replacement: 步骤 7 中的图像 1,2 SuperSonic Matrix Mid SC-999 LCD Replacement: 步骤 7 中的图像 2,2
      • Desolder the 4 Speaker Wires
      • These wires connect the speakers to the motherboard. They are the thinnest wires.
      • Be sure to wear protective eye wear. Also, keep in mind that the soldering iron will become extremely hot.
      添加评论
    1. SuperSonic Matrix Mid SC-999 LCD Replacement, Microphone: 步骤 8 中的图像 1,1
      • Remove the microphone from its compartment.
      • The microphone is located toward the bottom left corner of the device (assuming the speakers are located on the right side of you).
      询问修复机器人
      添加评论
    2. SuperSonic Matrix Mid SC-999 LCD Replacement: 步骤 9 中的图像 1,2 SuperSonic Matrix Mid SC-999 LCD Replacement: 步骤 9 中的图像 2,2
      • Use the soldering iron to remove the wires connected to the microphone.
      • If you're unfamiliar with soldering or desoldering, check out this guide.
      询问修复机器人
      添加评论
    1. SuperSonic Matrix Mid SC-999 LCD Replacement, FM Antenna: 步骤 10 中的图像 1,2 SuperSonic Matrix Mid SC-999 LCD Replacement, FM Antenna: 步骤 10 中的图像 2,2
      • Use a soldering iron to desolder the region circled in red.
      • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so be aware of your surroundings.
      询问修复机器人
      添加评论
    2. SuperSonic Matrix Mid SC-999 LCD Replacement: 步骤 11 中的图像 1,2 SuperSonic Matrix Mid SC-999 LCD Replacement: 步骤 11 中的图像 2,2
      • Desolder the FM antenna from the motherboard.
      询问修复机器人
      添加评论
    1. SuperSonic Matrix Mid SC-999 LCD Replacement, Motherboard: 步骤 12 中的图像 1,2 SuperSonic Matrix Mid SC-999 LCD Replacement, Motherboard: 步骤 12 中的图像 2,2
      • Remove the large ribbon cable from the socket that attaches it to the motherboard.
      • Pull down on the dark grey sliders located on both sides of the ribbon cable to release it.
      询问修复机器人
      添加评论
    2. SuperSonic Matrix Mid SC-999 LCD Replacement: 步骤 13 中的图像 1,2 SuperSonic Matrix Mid SC-999 LCD Replacement: 步骤 13 中的图像 2,2
      • Remove the small ribbon cable from the socket that attaches it to the motherboard.
      • Flip the dark grey latch to release the ribbon cable from the motherboard.
      询问修复机器人
      添加评论
    3. SuperSonic Matrix Mid SC-999 LCD Replacement: 步骤 14 中的图像 1,3 SuperSonic Matrix Mid SC-999 LCD Replacement: 步骤 14 中的图像 2,3 SuperSonic Matrix Mid SC-999 LCD Replacement: 步骤 14 中的图像 3,3
      • Remove the four Phillips #00 screws attaching the motherboard to the device.
      询问修复机器人
      添加评论
    1. SuperSonic Matrix Mid SC-999 LCD Replacement, LCD: 步骤 15 中的图像 1,3 SuperSonic Matrix Mid SC-999 LCD Replacement, LCD: 步骤 15 中的图像 2,3 SuperSonic Matrix Mid SC-999 LCD Replacement, LCD: 步骤 15 中的图像 3,3
      • Ensure that the motherboard and all other items are off before continuing.
      • Separate the screen and back housing by gently pulling on it.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
团队
Dr Shaverz boyz Dr Shaverz boyz 的会员
Community
3 名成员
创作了63篇指南
1指南评论
what is the part number & where can I get a replacement screen for the SC-8809
impaired27 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 35
总计 1,386
