跳转到主内容
加入维修社区 - 创建账户
SuperSonic Matrix Mid SC-999 Headphone Jack Replacement
你所需要的
    1. SuperSonic Matrix Mid SC-999 Headphone Jack Replacement, Back Cover: 步骤 1 中的图像 1,1
      • Wedge the plastic opening tool between the back cover of the device and the front panel.
      • You will hear a snapping sound as the cover is separated from the body of the device.
      询问修复机器人
      添加评论
    2. SuperSonic Matrix Mid SC-999 Headphone Jack Replacement: 步骤 2 中的图像 1,1
      • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
      • Again, you will hear a snapping sound as the cover is separated from the body of the device.
      询问修复机器人
      添加评论
    3. SuperSonic Matrix Mid SC-999 Headphone Jack Replacement: 步骤 3 中的图像 1,2 SuperSonic Matrix Mid SC-999 Headphone Jack Replacement: 步骤 3 中的图像 2,2
      • Lift the back cover from the body of the device to expose the internal components.
      询问修复机器人
      添加评论
    1. SuperSonic Matrix Mid SC-999 Headphone Jack Replacement, Headphone Jack: 步骤 4 中的图像 1,1
      • Locate the headphone jack on the device.
      询问修复机器人
      添加评论
    2. SuperSonic Matrix Mid SC-999 Headphone Jack Replacement: 步骤 5 中的图像 1,2 SuperSonic Matrix Mid SC-999 Headphone Jack Replacement: 步骤 5 中的图像 2,2
      • Desolder the 5 soldered connections (marked in red) that connect the headphone jack to the device.
      • If you're unfamiliar with soldering or desoldering check out this guide.
      • Be sure to wear protective eye wear. The soldering iron will become extremely hot, so be mindful in your handling.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
Dr Shaverz boyz Dr Shaverz boyz 的会员
Community
3 名成员
创作了70篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 32
总计 546
