跳转到主内容
加入维修社区 - 创建账户
Super Nintendo Cartridge Replacement
你所需要的
  1. Super Nintendo Cartridge Replacement, Cartridge: 步骤 1 中的图像 1,2 Super Nintendo Cartridge Replacement, Cartridge: 步骤 1 中的图像 2,2
    • On the bottom front corners of the cartridge you should see two screws using the 3.8mm "Gamebit" screwdriver bit. A 3.0U Spanner bit can also get them out.
    • Once the screws are out, slide the front part of the plastic casing down to clear the tabs on the top of the case.
    • The two halves of the case should open easily.
  2. Super Nintendo Cartridge Replacement: 步骤 2 中的图像 1,1
    • At this point the game board and pins are freely accessible.
    • Here you can fully clean the pin set and inspect for damage to the circuit board.
    • Cleaning the pins is the easiest part; use a cotton swab and either a rich mixture isopropyl alcohol or Brasso. Other people swear by an eraser(the white kind), but it can lead to damage if you're not careful. Personally, Brasso works the best.
  3. Super Nintendo Cartridge Replacement: 步骤 3 中的图像 1,2 Super Nintendo Cartridge Replacement: 步骤 3 中的图像 2,2
    • NOTE: The top edges of the board are made asymmetrically so it can only go into the casing one way. Near the Blue Circles
    • Games with battery backup (allowing for save games to be stored in SRAM) allow access to the battery at this point for replacement. Most of the time the battery is a button cell: CR2032.
    • The battery is soldered in. You will have to break it out and re-solder the new battery in.
结论
To reassemble the cartridge, follow these instructions in reverse order.
23等其他人完成本指南。
BWest
于09/02/10注册
3,441 声望
创作了2篇指南
团队
OPEN OPEN 的会员
Community
88 名成员
创作了30篇指南
1指南评论
Nintendo fix talk Nancy Places Nick III Fix SNES Alive Green
nj8324805 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 28
过去 30 天: 128
总计 37,477
