简介
Use this guide to replace the pneumatic spring in your Strive AL 6.0 Race.
你所需要的
Before you begin with the dismount procedure of your pneumatic spring you should press your shapeshifter lever once to make sure your bike is in XC mode.
Reduce tensile stress by twisting the adjuster on your shapeshifter cable as close as you can to the lever.
Take or clip off the cap at the end of the pulling cable. If you want to clip it off, you can use a side cutter or something similar.
Loosen the clamp of the pulling cable with a 2mm hexagonal.
Hold the pneumatic spring with one and the pulling cable with the other hand. Now you can easily pull the spring off the cable.
To reassemble your bike, follow these instructions in reverse order.
