跳转到主内容
SteelSeries Nimbus+ Controller Battery Replacement
你所需要的
  1. SteelSeries Nimbus+ Controller Battery  Replacement, Remove the phone mount: 步骤 1 中的图像 1,2 SteelSeries Nimbus+ Controller Battery  Replacement, Remove the phone mount: 步骤 1 中的图像 2,2
    • Use your fingers to remove the phone mount by pulling it straight out of the controller.
  2. SteelSeries Nimbus+ Controller Battery  Replacement, Remove the sticker: 步骤 2 中的图像 1,1
    • Use your fingers to remove the sticker located on the back cover of the Nimbus+.
    • If you have trouble removing the sticker heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath.
  3. SteelSeries Nimbus+ Controller Battery  Replacement, Unscrew the back cover: 步骤 3 中的图像 1,1
    • Use a Y1 Tri-point screwdriver to remove the five 9.1 mm-long screws securing the back cover.
  4. SteelSeries Nimbus+ Controller Battery  Replacement, Insert an opening pick: 步骤 4 中的图像 1,2 SteelSeries Nimbus+ Controller Battery  Replacement, Insert an opening pick: 步骤 4 中的图像 2,2
    • The back cover is held in place by plastic clips.
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the right controller handle.
  5. SteelSeries Nimbus+ Controller Battery  Replacement, Release the plastic clips: 步骤 5 中的图像 1,2 SteelSeries Nimbus+ Controller Battery  Replacement, Release the plastic clips: 步骤 5 中的图像 2,2
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the right edge.
  6. SteelSeries Nimbus+ Controller Battery  Replacement, Insert an opening pick: 步骤 6 中的图像 1,2 SteelSeries Nimbus+ Controller Battery  Replacement, Insert an opening pick: 步骤 6 中的图像 2,2
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the left controller handle.
  7. SteelSeries Nimbus+ Controller Battery  Replacement, Release the plastic clips: 步骤 7 中的图像 1,2 SteelSeries Nimbus+ Controller Battery  Replacement, Release the plastic clips: 步骤 7 中的图像 2,2
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the left edge.
  8. SteelSeries Nimbus+ Controller Battery  Replacement, Unfold the back cover assembly: 步骤 8 中的图像 1,3 SteelSeries Nimbus+ Controller Battery  Replacement, Unfold the back cover assembly: 步骤 8 中的图像 2,3 SteelSeries Nimbus+ Controller Battery  Replacement, Unfold the back cover assembly: 步骤 8 中的图像 3,3
    • Carefully fold the back cover assembly to the top of the SteelSeries Nimbus+ and bring it in an 90 degree angle.
    • Do not try to remove the back cover assembly all the way yet! It is still connected to mainboard.
  9. SteelSeries Nimbus+ Controller Battery  Replacement, Disconnect the battery cable: 步骤 9 中的图像 1,3 SteelSeries Nimbus+ Controller Battery  Replacement, Disconnect the battery cable: 步骤 9 中的图像 2,3 SteelSeries Nimbus+ Controller Battery  Replacement, Disconnect the battery cable: 步骤 9 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of blunt nose tweezers to disconnect the battery cable from the mainboard.
  10. SteelSeries Nimbus+ Controller Battery  Replacement, Remove the back cover assembly: 步骤 10 中的图像 1,1
    • Remove the back cover assembly.
  11. SteelSeries Nimbus+ Controller Battery  Replacement, Pry up the battery: 步骤 11 中的图像 1,2 SteelSeries Nimbus+ Controller Battery  Replacement, Pry up the battery: 步骤 11 中的图像 2,2
    • The battery is held in place by mild adhesive.
    • Insert the edge of an opening pick into the gap between the battery and the back cover assembly.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Use the opening pick to carefully pry up the battery and loosen the adhesive.
  12. SteelSeries Nimbus+ Controller Battery  Replacement, Remove the battery: 步骤 12 中的图像 1,1
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • Make sure to align the battery and the back cover of the controller correctly during reassembly.
结论
For optimal performance, calibrate your newly installed battery after completing this guide.
另外一个人完成了本指南。
Adriana Zwink
于12/18/19注册
62,316 声望
创作了167篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,649篇指南
1指南评论
Useless directions. The battery has 3 connectors. What is the mode? Where can you buy it? Polarity? If you have one with the right voltage and amps; but has two connectors what's do you do?
All this so-called repair guide says is: "This is how you open the case". Fantastic and then what???
Baldy - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 33
总计 1,939
