简介
The GameDAC control wheel is the component that controls the dial of the GameDAC. This electrical component is called a potentiometer. When replacing the potentiometer, one should be careful of wired connections on the circuit board. Follow this guide to safely replace the potentiometer.
你所需要的
Remove the plastic cover using the iFixit opening tool to pry the cover open.
Insert opening picks to keep the cover open as you work your way around the GameDAC.
Pop the cover off.
5等其他人完成本指南。
3条评论
Hi there,
do you know what type of potentiometer is needed?
Greetings
Chris
I would like to know too. Cause it failed for me as well!!
