跳转到主内容
SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement
你所需要的
  1. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement, GameDAC Potentiometer: 步骤 1 中的图像 1,3 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement, GameDAC Potentiometer: 步骤 1 中的图像 2,3 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement, GameDAC Potentiometer: 步骤 1 中的图像 3,3
    • Remove the plastic cover using the iFixit opening tool to pry the cover open.
    • Insert opening picks to keep the cover open as you work your way around the GameDAC.
    • Pop the cover off.
  2. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: 步骤 2 中的图像 1,2 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: 步骤 2 中的图像 2,2
    • Remove the control wheel from the GameDAC by pulling on the knob.
  3. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: 步骤 3 中的图像 1,2 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: 步骤 3 中的图像 2,2
    • Remove the five 6mm screws using the Phillips #0 driver head.
    • There is one screw hidden on the upper right-hand side of the display.
  4. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: 步骤 4 中的图像 1,2 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: 步骤 4 中的图像 2,2
    • Hold the sides of the GameDAC and pull apart.
    • Don't pull the two sides apart quickly or forcefully to avoid tearing the wire connection between the two boards.
  5. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: 步骤 5 中的图像 1,1
    • Remove the three 4mm screws from the circuit board using the Phillips #0 driver head.
  6. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: 步骤 6 中的图像 1,2 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: 步骤 6 中的图像 2,2
    • Desolder the seven potentiometer pins from the board to remove the button.
    • For help desoldering connections, follow this useful guide on 如何焊接和拆焊.
    • Use caution when soldering. The heated tip may cause damage to the board or burn you.
结论
5等其他人完成本指南。
团队
Cal Poly, Team S18-G1, White Winter 2019 Cal Poly, Team S18-G1, White Winter 2019 的会员
CPSU-WHITE-W19S18G1
4 名成员
创作了21篇指南
3条评论
Hi there,
do you know what type of potentiometer is needed?
Greetings
Chris
Christian Humann - 回复
I would like to know too. Cause it failed for me as well!!
Antonis Lazarakis - 回复
Can I replace the Oled Screen with 2,42 inch arduino oled display that also have 24pin flex?
Muso!27 - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 18
过去 30 天: 70
总计 4,486
