跳转到主内容
SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement
你所需要的
  1. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement, Headset Ear Cushions: 步骤 1 中的图像 1,2 SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement, Headset Ear Cushions: 步骤 1 中的图像 2,2
    • Lift the edge of the cushion and pull out slightly.
    • Work your way around the cushion until it comes off completely.
    • Repeat for the other cushion.
  2. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement, Headset Circuit Board: 步骤 2 中的图像 1,1
    • Remove the three 5mm screws with a Phillips #0 driver head on the headphone with the microphone.
  3. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: 步骤 3 中的图像 1,1
    • Lift the speaker off the headset to expose the circuit board.
    • Be careful not to lift the speaker too quickly or too forcefully to prevent the wires from being pulled out of their connections.
  4. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: 步骤 4 中的图像 1,1
    • Remove the three 5mm screws using a Phillips #0 driver head.
  5. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: 步骤 5 中的图像 1,1
    • Lift the circuit board out of the plastic housing.
    • Press in on the volume wheel while pulling on the circuit board to help maneuver the circuit board out of the housing.
  6. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement, Microphone Cable: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Pull up on the wires connected to the circuit board using tweezers to remove the circuit board from inside the headset.
  7. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: 步骤 7 中的图像 1,1
    • Desolder the six wired connections on the circuit board.
    • For help desoldering connections, follow this useful guide on 如何焊接和拆焊.
    • Use caution when soldering. The heated tip may cause damage to the board or burn you.
  8. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: 步骤 8 中的图像 1,2 SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: 步骤 8 中的图像 2,2
    • Lift up the wire on the rotating wheel with tweezers to move it out of the way of the screws.
    • Remove the two 5mm screws with a Phillips #0 driver head.
  9. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: 步骤 9 中的图像 1,2 SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: 步骤 9 中的图像 2,2
    • Pull out the rotating wheel from the headset casing.
    • Remove the microphone from the casing with the rotator wheel.
    • After removing the rotating wheel, lift the wheel up and use your other hand to feed the microphone through the case.
  10. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: 步骤 10 中的图像 1,2 SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: 步骤 10 中的图像 2,2
    • Pull the microphone wire out of the wheel.
    • Forcefully removing the microphone from the wheel may break the plastic wheel.
    • Pull the wire and wheel apart to remove the entire component.
结论
7等其他人完成本指南。
Vanessa Beeler
于01/24/19注册
296 声望
撰写一个指南
团队
Cal Poly, Team S18-G1, White Winter 2019 Cal Poly, Team S18-G1, White Winter 2019 的会员
CPSU-WHITE-W19S18G1
4 名成员
创作了21篇指南
9条评论
can Ii do this with my Arctis 5?
Vantura - 回复
Ugh! Why do they all fail at mic design so bad? Something that has been mastered for decades. It blows my mind.
Chris - 回复
Is there any place where i can get this cable? I also need a new mic for the wireless pro but steelseries dont sell parts. Somehow it came off and i lost it.
robinmusch - 回复
&&^& my mic died and i don’t have warranty wtf -_-
taps_so - 回复
The left earpiece on mine has a different screw type than phillips for some reason. I think it’s a kind of hex screw but I have hex heads and none worked. Strange that the left and right earpieces use different screws.
Darren Peterson - 回复
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 46
过去 30 天: 171
总计 12,556
