跳转到主内容
SteelSeries Arctis Pro Plus GameDAC 3.5mm Headphone Jack Replacement
你所需要的
  1. SteelSeries Arctis Pro Plus GameDAC 3.5mm Headphone Jack Replacement, 3.5mm Headphone Jack: 步骤 1 中的图像 1,2 SteelSeries Arctis Pro Plus GameDAC 3.5mm Headphone Jack Replacement, 3.5mm Headphone Jack: 步骤 1 中的图像 2,2
    • Lift the edge of the cushion and slightly pull out.
    • Work your way around the cushion until it comes off.
    • Repeat for the other cushion.
  2. SteelSeries Arctis Pro Plus GameDAC 3.5mm Headphone Jack Replacement: 步骤 2 中的图像 1,1
    • Remove the three 5mm screws with a Phillips #0 driver head on the headphone with the microphone.
  3. SteelSeries Arctis Pro Plus GameDAC 3.5mm Headphone Jack Replacement: 步骤 3 中的图像 1,1
    • Lift the speaker off the headset to expose the circuit board.
    • Be careful not to lift the speaker too quickly or too forcefully to prevent the wires from being pulled out of their connections.
  4. SteelSeries Arctis Pro Plus GameDAC 3.5mm Headphone Jack Replacement: 步骤 4 中的图像 1,1
    • Remove the three 5mm screws using a Phillips #0 driver head.
  5. SteelSeries Arctis Pro Plus GameDAC 3.5mm Headphone Jack Replacement: 步骤 5 中的图像 1,1
    • Lift the circuit board out of the plastic housing.
    • Press in on the volume wheel while pulling on the circuit board to help maneuver the circuit board out of the housing.
  6. SteelSeries Arctis Pro Plus GameDAC 3.5mm Headphone Jack Replacement: 步骤 6 中的图像 1,2 SteelSeries Arctis Pro Plus GameDAC 3.5mm Headphone Jack Replacement: 步骤 6 中的图像 2,2
    • Desolder the three connecting audio jack leads from the circuit board.
    • For help desoldering connections, follow this useful guide on 如何焊接和拆焊.
    • Use caution when soldering. The heated tip may cause damage to the board or burn you.
结论
5等其他人完成本指南。
Juan Gonzalez
于01/24/19注册
422 声望
创作了2篇指南
团队
Cal Poly, Team S18-G1, White Winter 2019 Cal Poly, Team S18-G1, White Winter 2019 的会员
CPSU-WHITE-W19S18G1
4 名成员
创作了21篇指南
一条评论
hey @juangonzal87030 I am unable to take out circuit board out of my Arctic Wireless Pro even even when all the screws are taken out. I am unable to understand what am I missing over here. Can you help
Ashutosh Kumar Singh - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 71
总计 8,838
