简介
This guide contains a selection of photos and chip identification summary for the main board of Valve's Steam Deck.
Check out our Steam Deck Teardown for more details.
Special thanks to community member CChin for his contribution!
视频概述
IC Identification, Pt. 1:
AMD/Valve 100-000000405 Quad-Core Application Processor w/ GPU
Micron MT62F1G32D4DR-031 WT:B 4 GB LPDDR5 SDRAM Memory
Winbond W25Q128JW 16 MB Serial NOR FLASH Memory
Analogix ANX7580 DisplayPort to Single MIPI Receiver
Cirrus Logic CS35L41B Audio Amplifier
Maxim Integrated MAX77961 USB Type-C Li-Ion Battery Charger
O2Micro OZ536 Backlight LED Driver
IC Identification, Pt. 2:
Monolithic Power Systems MP2845 Digital 6-Phase Controller
Monolithic Power Systems MP86902B 35 A Power Stage
Monolithic Power Systems MP86903C Power Stage
Likely Monolithic Power Systems NB688C Synchronous Buck Converter
Monolithic Power Systems NB691 Synchronous Buck Converter
Monolithic Power Systems NB690G Synchronous Buck Converter
Possibly Monolithic Power Systems NB591 Synchronous Buck Converter
IC Identification:
ITE Tech IT5570VG Embedded Controller (likely)
O2Micro OZ711 Card Reader Controller
Maxim Integrated MAX77958 USB Type-C & USB Power Delivery Controller
Diodes Incorporated PI3USB102 USB 2.0 SPDT Analog Switch
Texas Instruments TPS22976 Load Switch
23条评论
Interesting how Valve went with a full-custom APU from AMD. I thought they’d use an off-the-shelf chip like the 4500U.
Yeah i know what you mean!
They most likely they where wanting it to not be that thick,
so not like a laptop or desktop CPU for it,
Due to it being kinda thick!
I assume the only major difference between this and an off the shelf APU is that this APU just has everything the steam deck does not utilize disabled or removed for power consumption reasons. I doubt it goes much deeper than that.
Alyx -
Good Point
See what you mean
The 4500u has 6 EC Vega GPU, while the Steameck APU has an 8 ECU RDNA 2 GPU. Plus the custom APU gives them more control than a OTS apu.
