简介
使用此指南安全地取下并更換Steam Deck LCD中磨損或失效的電池。
為了您的安全,請打開您的Steam Deck並在開始此過程之前允許電池完全放電。 充電的鋰聚合物電池如果意外刺穿可能非常危險。 加熱充電的電池是火災隱患。 如何處理鼓脹電池?如果您的電池看起來鼓脹或腫脹,請採取額外的預防措施。
注意: Steam Deck的電池黏性很強,需要多次加熱和撬動。iOpener產生的熱量可能不足以鬆動膠粘劑,因此建議使用熱風槍(或替代品,如吹風機)進行此過程。
請記住:在維修設備時,請遵循一般的靜電放電(ESD)安全程序
在取下電池後不要再使用它,因為這可能存在安全隱患。用新電池替換它。
注意: Valve在2023年初開始發貨帶有更新內部設計的Steam Deck LCD。您的Steam Deck可能與照片中所示不同,但程序非常相似。取下後蓋的指南以檢查您的版本。原始的Steam Deck將具有金屬主板盾和具有方形邊的風扇,如此處所見。更新後的Steam Deck將具有黑色主板盾和具有曲線邊的風扇,如此處所見。在此處查找Steam Deck OLED指南。
你所需要的
视频概述
將電池移除
使用無絨布沾點酒精(>90%)將電池殘膠清除。不要使用過多液體,避免讓液體滲漏到機身上的切口。
將新電池下電池膠保護片一角的撕開,貼在對應舊電池的地方
將剩下的保護片撕開並用力按壓固定好電池
要重新駔裝你的裝置,請倒序觀看此指南
請將你的電子垃圾帶到R2或e- steward認證的回收商.
拆解不如預期?basic troubleshooting,或者到Steam Deck 問題論壇 尋求幫助.
要重新駔裝你的裝置,請倒序觀看此指南
26等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
10条评论
Is it safe to apply small amounts of >90% isopropyl alcohol under the battery to loosen the adhesive bond? Or would that drip into the screen or other components and potentially cause damage?
Your mileage may vary. Isopropyl alcohol may be an effective method to loosen the adhesive, but you run the risk of excess leaking onto or into the display or other components, due to the cutouts on the battery tray. Your second sentence is spot-on, hence the recommendation to carefully use heat instead.
Why couldn’t they of used pull tabs for the adhesive so this process would not be so difficult and tedious. It would also be less risk of over heating the battery/steam deck or puncturing the battery. This is really the only design choice I can criticize of the steam deck. Pull tabs would of made this a repair the average person could achieve.
I feel like patience is everything in this scenario I mean. Just take your time and relax & it will all be ok ! When dealing with particular situations like this just take you're time simple as that I promise. Especially, since Ifixit.com has some of the best guides EVER!!
It seems crazy to me that they made this process so difficult, surely battery is one of (if not THE) most common things that you'll need to eventually replace? I suppose they must have been limited by what they could achieve?
