跳转到主内容
Spin Master Boxer Robot Speaker Replacement
你所需要的
  1. Spin Master Boxer Robot Speaker Replacement, Robot Screen: 步骤 1 中的图像 1,1
    • Set Spin Master Boxer on your workspace so that the bottom panel faces upwards.
  2. Spin Master Boxer Robot Speaker Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #00 screw driver, unscrew the four 4mm screws in each corner of the bottom panel.
  3. Spin Master Boxer Robot Speaker Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the bottom panel of the Spin Master Boxer by lifting up, away from the main body of robot.
  4. Spin Master Boxer Robot Speaker Replacement: 步骤 4 中的图像 1,2 Spin Master Boxer Robot Speaker Replacement: 步骤 4 中的图像 2,2
    • While holding onto the axels of the wheels, gently pull the top panel of the robot away from its body.
    • Be aware when removing the panel that multiple wires connect it to the body of the Spin Master Boxer.
  5. Spin Master Boxer Robot Speaker Replacement: 步骤 5 中的图像 1,1
    • Remove the plastic screen from the body of the robot. It should come off easily as it is not attached by anything.
  6. Spin Master Boxer Robot Speaker Replacement, Robot Speaker: 步骤 6 中的图像 1,2 Spin Master Boxer Robot Speaker Replacement, Robot Speaker: 步骤 6 中的图像 2,2
    • Using a Phillips #00 screwdriver, unscrew the two 3mm screws connecting the black speaker cover to the top panel.
  7. Spin Master Boxer Robot Speaker Replacement: 步骤 7 中的图像 1,1
    • Remove the speaker cover and you will be left looking at the speaker.
    • The speaker is soldered onto the top panel so additional measures must be taken to completely remove it. See 如何焊接和拆焊
结论
Lauren Roide
于04/16/19注册
739 声望
创作了5篇指南
团队
Cal Poly, Team S1-G1, Maness Spring 2019 Cal Poly, Team S1-G1, Maness Spring 2019 的会员
CPSU-MANESS-S19S1G1
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 11
总计 1,279
