跳转到主内容
Spin Master Boxer Robot Battery Replacement
你所需要的
  1. Spin Master Boxer Robot Battery Replacement, Robot Screen: 步骤 1 中的图像 1,1
    • Set Spin Master Boxer on your workspace so that the bottom panel faces upwards.
  2. Spin Master Boxer Robot Battery Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #00 screw driver, unscrew the four 4mm screws in each corner of the bottom panel.
  3. Spin Master Boxer Robot Battery Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the bottom panel of the Spin Master Boxer by lifting up, away from the main body of robot.
  4. Spin Master Boxer Robot Battery Replacement: 步骤 4 中的图像 1,2 Spin Master Boxer Robot Battery Replacement: 步骤 4 中的图像 2,2
    • While holding onto the axels of the wheels, gently pull the top panel of the robot away from its body.
    • Be aware when removing the panel that multiple wires connect it to the body of the Spin Master Boxer.
  5. Spin Master Boxer Robot Battery Replacement: 步骤 5 中的图像 1,1
    • Remove the plastic screen from the body of the robot. It should come off easily as it is not attached by anything.
  6. Spin Master Boxer Robot Battery Replacement, Robot Battery: 步骤 6 中的图像 1,2 Spin Master Boxer Robot Battery Replacement, Robot Battery: 步骤 6 中的图像 2,2
    • Lift the top panel away from the main body of the robot to expose the yellow battery.
  7. Spin Master Boxer Robot Battery Replacement: 步骤 7 中的图像 1,1
    • Insert index finger in between battery and plastic shell of robot, and push battery out of the battery holder toward the wire.
  8. Spin Master Boxer Robot Battery Replacement: 步骤 8 中的图像 1,1
    • Now that the battery is completely removed, additional efforts, like soldering the wires off, must be taken to replace the battery.
    • 如何焊接和拆焊
结论
2等其他人完成本指南。
Lauren Roide
于04/16/19注册
739 声望
创作了5篇指南
团队
Cal Poly, Team S1-G1, Maness Spring 2019 Cal Poly, Team S1-G1, Maness Spring 2019 的会员
CPSU-MANESS-S19S1G1
4 名成员
创作了10篇指南
3指南评论
Any tips on where to buy a replacement battery?
Chad Laughlin - 回复
In fact it’s easy, was able to put 1000 mah Lipo 952540 with a little stretching of battery plastic holder
Anton Litvinov - 回复
can we replace boxer’s USB slot?
Buchukoy Jimenez - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 22
总计 2,604
