跳转到主内容
Sphero Ollie LED Light Replacement
你所需要的
  1. Sphero Ollie LED Light Replacement, Tires and Hubcaps: 步骤 1 中的图像 1,1
    • Firmly grasp Ollie in one hand.
    • Remove the blue rubber tire in a peeling motion with your opposite hand.
  2. Sphero Ollie LED Light Replacement: 步骤 2 中的图像 1,2 Sphero Ollie LED Light Replacement: 步骤 2 中的图像 2,2
    • Continue to firmly hold Ollie in one hand.
    • Use a Plastic Opening Tool to gently pry off the hubcap.
    • Avoid inserting the Plastic Opening Tool into the empty holes, but instead use the tool near the tabs holding the hubcap in.
    • Do not aim the hubcap towards another person as it may pop off with force.
  3. Sphero Ollie LED Light Replacement, Motherboard: 步骤 3 中的图像 1,1
    • Loosen and remove the 10mm screw on each side of the device using a JIS 1 screwdriver tip.
    • Remove the plastic tire frame from the device
  4. Sphero Ollie LED Light Replacement: 步骤 4 中的图像 1,2 Sphero Ollie LED Light Replacement: 步骤 4 中的图像 2,2
    • Loosen and remove the four 10mm Screws on the underside of the device using a JIS 1 tip.
    • Firmly grasp the bottom of the device and pull the top half of the outer case off of the bottom.
  5. Sphero Ollie LED Light Replacement: 步骤 5 中的图像 1,2 Sphero Ollie LED Light Replacement: 步骤 5 中的图像 2,2
    • Loosen and remove the 10mm screws holding the blue tooth connector as well as the two 1 10 screws holding the motherboard to the case using the JIS #1 screwdriver
    • Loosen and remove the 10mm screws holding the antenna to the case.
    • Gently remove mother board from the case with an upward motion.
  6. Sphero Ollie LED Light Replacement, LED Light: 步骤 6 中的图像 1,3 Sphero Ollie LED Light Replacement, LED Light: 步骤 6 中的图像 2,3 Sphero Ollie LED Light Replacement, LED Light: 步骤 6 中的图像 3,3
    • Locate the first LED light by looking for the white plastic cover on the motherboard.
    • Flip the motherboard over, and locate the tabs holding on the plastic LED cover.
    • Pinch the tabs to the LED cover on the bottom side of the motherboard to remove the cover from the top side of the motherboard.
  7. Sphero Ollie LED Light Replacement: 步骤 7 中的图像 1,2 Sphero Ollie LED Light Replacement: 步骤 7 中的图像 2,2
    • Locate the second LED light by looking for the perpendicular section on the motherboard with a matching LED light soldered to it.
    • Carefully de-solder the adhered edges on both LED lights to remove from from the motherboard.
    • Use great care when using a soldering iron.
    • For more detailed information on how to solder, please see our How to Solder and Desolder Connections guide
结论
Krystal Hedrick
于10/30/17注册
364 声望
创作了3篇指南
团队
UW Tacoma, Team S1-G3, Rose Fall 2017 UW Tacoma, Team S1-G3, Rose Fall 2017 的会员
UWT-ROSE-F17S1G3
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 12
总计 311
