跳转到主内容
Zenbre SoundBank Z3 Speaker Replacement
你所需要的
  1. Zenbre SoundBank Z3 Speaker Replacement, Bottom Cover: 步骤 1 中的图像 1,2 Zenbre SoundBank Z3 Speaker Replacement, Bottom Cover: 步骤 1 中的图像 2,2
    • Power off the SoundBank Z3.
    • Turn over the device.
    • Peel the silicone feet up to remove.
    • No extra adhesive is needed to reapply the feet as long as the sticky side is not touched.
  2. Zenbre SoundBank Z3 Speaker Replacement: 步骤 2 中的图像 1,1
    • Remove all eight of the 11 mm Phillips screws from the bottom of the device.
  3. Zenbre SoundBank Z3 Speaker Replacement: 步骤 3 中的图像 1,2 Zenbre SoundBank Z3 Speaker Replacement: 步骤 3 中的图像 2,2
    • Remove the bottom panel speaker using an iFixit opening tool.
  4. Zenbre SoundBank Z3 Speaker Replacement, Motherboard Cover: 步骤 4 中的图像 1,3 Zenbre SoundBank Z3 Speaker Replacement, Motherboard Cover: 步骤 4 中的图像 2,3 Zenbre SoundBank Z3 Speaker Replacement, Motherboard Cover: 步骤 4 中的图像 3,3
    • Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
    • Remove the plastic panel.
  5. Zenbre SoundBank Z3 Speaker Replacement, Speakers: 步骤 5 中的图像 1,2 Zenbre SoundBank Z3 Speaker Replacement, Speakers: 步骤 5 中的图像 2,2
    • Remove the three screws that are holding the speaker down.
    • Be careful not to rip out the speaker while taking out the screws.
  6. Zenbre SoundBank Z3 Speaker Replacement: 步骤 6 中的图像 1,2 Zenbre SoundBank Z3 Speaker Replacement: 步骤 6 中的图像 2,2
    • Desolder the speaker joints from the motherboard. Follow this How To Solder guide for help with desoldering.
  7. Zenbre SoundBank Z3 Speaker Replacement: 步骤 7 中的图像 1,2 Zenbre SoundBank Z3 Speaker Replacement: 步骤 7 中的图像 2,2
    • Remove the speaker from the motherboard.
    • Remove the speaker ring.
    • Be careful not to remove other components in the speaker.
    • Repeat Steps 5-7 with the other speaker.
结论
另外一个人完成了本指南。
Cherian Thomas
于03/25/16注册
334 声望
创作了5篇指南
团队
UMass Dartmouth, Team 3-2, Bhusal Spring 2016 UMass Dartmouth, Team 3-2, Bhusal Spring 2016 的会员
UMASSD-BHUSAL-S16S3G2
5 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 10
总计 469
