跳转到主内容
Sophix TAB-730g Battery Replacement
你所需要的
  1. Sophix TAB-730g Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the back cover to gain access to the mother board.
    • Unscrew, with a 000 Philip's screwdriver, the 3.547 mm long screw located at the bottom of your tablet.
  2. Sophix TAB-730g Battery Replacement: 步骤 2 中的图像 1,1
    • Firmly slide the cover in the direction indicated by the arrow, away from the ports, with your hand to remove the back cover.
  3. Sophix TAB-730g Battery Replacement: 步骤 3 中的图像 1,1
    • Desolder the two wires connecting the battery to the mother board.
  4. Sophix TAB-730g Battery Replacement: 步骤 4 中的图像 1,1
    • Gently pry the battery off the back of the device using some force.
    • There is adhesive keeping the battery attached so a decent amount of force may need to be applied.
结论
2等其他人完成本指南。
JT Hiquet
于09/29/16注册
333 声望
创作了3篇指南
团队
IUPUI, Team 2-3, Harley Fall 2016 IUPUI, Team 2-3, Harley Fall 2016 的会员
IUPUI-HARLEY-F16S2G3
4 名成员
创作了6篇指南
一条评论
[|how do you know if the problem is or is not the battery?]
Don Taylor - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 367
