简介
Use this guide to remove the rear glass of the Sony Xperia Z4.
Opening the Sony Xperia Z4 will damage the waterproof seals on the device. If you do not replace the adhesive seals, your phone will function normally but will lose its water protection.
You’ll need replacement adhesive to reattach components when reassembling the device.
你所需要的
Before you begin, switch off your phone.
Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
If the adhesive becomes hard to cut it most likely cooled down. Use your iOpener to reheat it.
Insert a fourth opening pick under the top left corner of the back cover.
Slide the opening pick along the top edge of the phone to cut the adhesive.
Leave the opening pick in the top right corner to prevent the adhesive from resealing.
Secure the new back cover with pre-cut adhesive or double-sided adhesive tape after cleaning the according areas with isopropyl alcohol (+90%).
