跳转到主内容
Sony Xperia Z3 Compact Battery Replacement
你所需要的
  1. Sony Xperia Z3 Compact Battery Replacement, Sony Xperia Z3 Compact Battery Replacement: 步骤 1 中的图像 1,3 Sony Xperia Z3 Compact Battery Replacement, Sony Xperia Z3 Compact Battery Replacement: 步骤 1 中的图像 2,3 Sony Xperia Z3 Compact Battery Replacement, Sony Xperia Z3 Compact Battery Replacement: 步骤 1 中的图像 3,3
    • Heat the back cover of your Xperia Z3 Compact with an iOpener to loosen the adhesive underneath.
    • Lift up the back cover with a suction handle and put an opening pick in the gap.
    • Move the pick carefully around the edges to loosen the adhesive on every side of the phone.
    • Now you can pull up the back cover with the suction handle.
  2. Sony Xperia Z3 Compact Battery Replacement: 步骤 2 中的图像 1,2 Sony Xperia Z3 Compact Battery Replacement: 步骤 2 中的图像 2,2
    • Use a tweezer to remove the model label which is hooked in the right side of the frame.
    • Undo the flex cable of the NFC antenna with a tweezer.
  3. Sony Xperia Z3 Compact Battery Replacement: 步骤 3 中的图像 1,2 Sony Xperia Z3 Compact Battery Replacement: 步骤 3 中的图像 2,2
    • Unscrew the following screws which hold down the mid frame of the Sony Xperia Z3 Compact.
    • Two 2.7 mm Phillips #000
    • Three 2.5 mm Phillips #000
    • Use a Spudger to lift up the mid frame on each side.
    • Be careful and patient, the plastic mid frame is fragile and might break if bent too hard.
  4. Sony Xperia Z3 Compact Battery Replacement: 步骤 4 中的图像 1,3 Sony Xperia Z3 Compact Battery Replacement: 步骤 4 中的图像 2,3 Sony Xperia Z3 Compact Battery Replacement: 步骤 4 中的图像 3,3
    • Declamp the metal bracket which holds down the flex connector of the rear camera.
    • Unplug the flex connector of the rear camera and lift it out of its recess.
  5. Sony Xperia Z3 Compact Battery Replacement: 步骤 5 中的图像 1,2 Sony Xperia Z3 Compact Battery Replacement: 步骤 5 中的图像 2,2
    • Use a Spudger to unplug the headphone jack and sensor cable connector.
    • Unscrew the single 2.5 mm Phillips #000 screw on the upper left side of the motherboard.
  6. Sony Xperia Z3 Compact Battery Replacement: 步骤 6 中的图像 1,3 Sony Xperia Z3 Compact Battery Replacement: 步骤 6 中的图像 2,3 Sony Xperia Z3 Compact Battery Replacement: 步骤 6 中的图像 3,3
    • Unplug the battery and display flex connectors.
    • Open the compartments for the SIM card and the micro SD card and remove them.
  7. Sony Xperia Z3 Compact Battery Replacement: 步骤 7 中的图像 1,3 Sony Xperia Z3 Compact Battery Replacement: 步骤 7 中的图像 2,3 Sony Xperia Z3 Compact Battery Replacement: 步骤 7 中的图像 3,3
    • Use a Spudger to slightly lift up the motherboard.
    • Be careful! You need to thread the display flex cable through a gap in the motherboard while lifting it up. It is also connected to the vibration motor, which still sticks to the phone.
    • Take especially care of the two black connectors on the side of the battery. They break off easily during the removal of the motherboard.
    • Use a tweezer to take out the vibration motor and then remove the motherboard completely.
  8. Sony Xperia Z3 Compact Battery Replacement: 步骤 8 中的图像 1,3 Sony Xperia Z3 Compact Battery Replacement: 步骤 8 中的图像 2,3 Sony Xperia Z3 Compact Battery Replacement: 步骤 8 中的图像 3,3
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    • Gently pull out both of the black straps with the adhesive tabs underneath the battery.
    • Never pull out the straps upwards but always sideways. It can easily happen that you rupture the adhesive tabs. In this case use a plastic card to pry off the battery carefully,Use a little bit of heat if necessary!
    • Now you can remove the battery from the motherboard easily.
  9. Sony Xperia Z3 Compact Battery Replacement: 步骤 9 中的图像 1,3 Sony Xperia Z3 Compact Battery Replacement: 步骤 9 中的图像 2,3 Sony Xperia Z3 Compact Battery Replacement: 步骤 9 中的图像 3,3
    • Warm up the NFC antenna a little bit to loosen the adhesive underneath.
    • Carefully peel it off the battery. If the adhesive starts to crumble use a plastic card to loosen the adhesive.
结论
24等其他人完成本指南。
Tobias Isakeit
于03/31/14注册
129,301 声望
创作了189篇指南
团队
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 的会员
Business
1 名成员
创作了1,145篇指南
10指南评论
Thank you Tobias !
My Z3 compact starts now his second life :)
Guy Hard - 回复
Thank you for repairing your phone and giving it a second chance.
Tobias Isakeit -
Where do I need the Back Cover Adhesive Strips for?
Visser - 回复
The guide doesn’t mention that one needs new adhesive for the battery (the one I bought isn’t sold with it). It would therefore be wise to mention what kind of adhesive (two-sided, what thckness, etc.)
axel - 回复
Double sided tape is enough to keep it in place, as the back cover and midframe holds everything down for extra reinforcement. Sony sure makes their smartphones !&&* to repair, but that’s another rant.
William Nephew -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 31
过去 30 天: 178
总计 43,244
