跳转到主内容
Sony Xperia Z1s Charging Port Replacement
你所需要的
  1. Sony Xperia Z1s Charging Port Replacement, Battery: 步骤 1 中的图像 1,1
    • Insert the opening pick in the crease between the rear cover and the body of the phone.
    • Pry along the edge to lift and remove the back cover.
  2. Sony Xperia Z1s Charging Port Replacement: 步骤 2 中的图像 1,1
    • Using the T4 Torx screwdriver, remove five 5 mm screws from the panel above the battery.
    • Remove the panel by grabbing its bottom edge and lifting upwards.
  3. Sony Xperia Z1s Charging Port Replacement: 步骤 3 中的图像 1,1
    • Use the opening pick to pry off the battery flex cable.
  4. Sony Xperia Z1s Charging Port Replacement: 步骤 4 中的图像 1,1
    • Using the T4 Torx screwdriver, remove two 5 mm screws from the bottom corners of the battery.
  5. Sony Xperia Z1s Charging Port Replacement: 步骤 5 中的图像 1,1
    • Firmly press the suction cup onto the battery.
    • Pull the battery out using the suction handle.
  6. Sony Xperia Z1s Charging Port Replacement, Motherboard: 步骤 6 中的图像 1,1
    • Use the opening pick to pry off the camera flex cable.
    • Continue to lift the flex cable upward until the camera pops out.
  7. Sony Xperia Z1s Charging Port Replacement: 步骤 7 中的图像 1,1
    • Use the opening pick to pry off the three flex cables on the bottom of the motherboard.
    • Do the same for the one flex cable at the top of the motherboard.
  8. Sony Xperia Z1s Charging Port Replacement: 步骤 8 中的图像 1,1
    • Use the opening pick to pry off the black plastic cover above the top of the motherboard.
  9. Sony Xperia Z1s Charging Port Replacement: 步骤 9 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use a pair of tweezers to lift up the motherboard.
    • If you are having trouble removing the motherboard, try lifting up the left edge first and sliding the rest of the motherboard out.
  10. Sony Xperia Z1s Charging Port Replacement: 步骤 10 中的图像 1,1
    • Use a pair of tweezers to remove the pin connection on the motherboard.
    • Fully remove the motherboard from the device.
  11. Sony Xperia Z1s Charging Port Replacement, Charging Port: 步骤 11 中的图像 1,1
  12. Sony Xperia Z1s Charging Port Replacement: 步骤 12 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use a pair of tweezers to remove the charging port from the device.
结论
Jacob Willey
于09/28/21注册
85 声望
撰写一个指南
团队
Clemson, Team 4-4, Hunter Fall 2021 Clemson, Team 4-4, Hunter Fall 2021 的会员
CLEM-HUNTER-F21S4G4
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 150
