跳转到主内容
Sony Xperia XZ Premium Motherboard Replacement
你所需要的
  1. Sony Xperia XZ Premium Motherboard Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Place a heated iOpener on the back panel of the phone to melt the adhesive inside.
    • The iOpener or your desired heat source can be very hot and can heat up the phone, so make sure you do not burn yourself.
    • Follow this guide for directions on using the iOpener.
    Is it okay to use a hair dryer instead of iOpener?
    091 03718 - 回复
  2. Sony Xperia XZ Premium Motherboard Replacement: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    购买
    • Slide a thin plastic card under the back panel and around the perimeter of the phone to remove the adhesive.
  3. Sony Xperia XZ Premium Motherboard Replacement: 步骤 3 中的图像 1,1
    • Take hold of the back panel with your fingers and remove.
  4. Sony Xperia XZ Premium Motherboard Replacement, Frame: 步骤 4 中的图像 1,1
    • Orient the phone horizontally with the front screen facing down and the camera on the bottom left corner.
  5. Sony Xperia XZ Premium Motherboard Replacement: 步骤 5 中的图像 1,2 Sony Xperia XZ Premium Motherboard Replacement: 步骤 5 中的图像 2,2
    • Remove nine 3.9mm Phillips #000 screws.
    • Make sure to turn carefully in the counter-clockwise direction or you may wear out the thread and shape of the screws. You will not be able to remove the screws once they are damaged!
    • When unscrewing, remember "Left Loosey, Righty Tighty!"
  6. Sony Xperia XZ Premium Motherboard Replacement: 步骤 6 中的图像 1,1
    • Place the spudger under the top left corner frame piece and lift to loosen.
  7. Sony Xperia XZ Premium Motherboard Replacement: 步骤 7 中的图像 1,1
    • Grab hold of the top left frame piece with your fingers and gently wiggle and lift to remove.
  8. Sony Xperia XZ Premium Motherboard Replacement: 步骤 8 中的图像 1,1
    • Place the spudger under the bottom left frame piece and lift to loosen it.
  9. Sony Xperia XZ Premium Motherboard Replacement: 步骤 9 中的图像 1,1
    • Grab hold of bottom left frame piece with your fingers and lift gently.
    • When dislodging the left frame piece, carefully wiggle the piece while lifting it vertically to prevent any damage to the wedges on the frame. This applies for all of the other frame pieces you will remove after this step!
  10. Sony Xperia XZ Premium Motherboard Replacement: 步骤 10 中的图像 1,1
    • Place the spudger under the top right frame piece and lift to loosen it.
    このとき、バイブレーターのカバーと、バイブレーターのコネクタに注意します。無理矢理引きちぎらないようにしてください。
    satore - 回复
    上部右側フレームの下には、バイブレータがあります。バイブレータとマザーボードをつなぐコネクタはなぜか上部右上フレームに接着されています(接着されていなくてもよい気がします)。
    上部右側フレームを持ち上げる際には、そっとコネクタを外した方が安全です。
    https://youtu.be/JmN7pZdgJDU?t=133
    バイブレーターのカバーは、シリコン製です。外れやすいので見失わないようにしてください。
    satore - 回复
  11. Sony Xperia XZ Premium Motherboard Replacement: 步骤 11 中的图像 1,1
    • Grab hold of the top right frame piece with your fingers and lift.
  12. Sony Xperia XZ Premium Motherboard Replacement, Motherboard: 步骤 12 中的图像 1,1
    • Insert your nail under the top left connector and push to disconnect it.
  13. Sony Xperia XZ Premium Motherboard Replacement: 步骤 13 中的图像 1,1
    • Grab hold of the metal part of the connector with your fingers and lift.
  14. Sony Xperia XZ Premium Motherboard Replacement: 步骤 14 中的图像 1,1
    • Insert your nail under the metal part of the bottom left connector.
  15. Sony Xperia XZ Premium Motherboard Replacement: 步骤 15 中的图像 1,1
    • Push the bottom left connector with your finger to disconnect it.
  16. Sony Xperia XZ Premium Motherboard Replacement: 步骤 16 中的图像 1,1
    • Insert your nail under the center topmost connector and push to loosen it.
  17. Sony Xperia XZ Premium Motherboard Replacement: 步骤 17 中的图像 1,1
    • Grab hold of the top connector with your fingers and lift to disconnect it.
  18. Sony Xperia XZ Premium Motherboard Replacement: 步骤 18 中的图像 1,1
    • Insert your nail under the metal tab of the connector above the battery and push to loosen it.
  19. Sony Xperia XZ Premium Motherboard Replacement: 步骤 19 中的图像 1,1
    • Pull the metal tab of the connector towards you with your fingers to disconnect the pins.
  20. Sony Xperia XZ Premium Motherboard Replacement: 步骤 20 中的图像 1,1
    • Insert spudger in the gap above the battery and lift to loosen the motherboard.
    • Use the spudger to slide under the edges of the motherboard if the motherboard does not seem to loosen after the above step.
    フロントカメラの取り外し手順が省かれており、最低限カメラのシールドを止めているネジを取り外す必要があります。
    また、SIMカード、SDカードも前もって外しておかないと、マザーボードが浮いてきません。
    Takahiro Yoshinaga - 回复
  21. Sony Xperia XZ Premium Motherboard Replacement: 步骤 21 中的图像 1,1
    • Insert the spudger in the gap between the motherboard and the left side of the battery to further lift out the motherboard.
    この段階で既に見えていますが、バッテリと本体を固定する両面テープの耳を引っ張れば、バッテリはすぐに外れます。
    satore - 回复
  22. Sony Xperia XZ Premium Motherboard Replacement: 步骤 22 中的图像 1,1
    • Grab hold of the motherboard with your fingers and lift it out of the phone gently.
结论
5等其他人完成本指南。
Gelene Amog
于04/18/18注册
1,165 声望
创作了5篇指南
团队
Cal Poly, Team S18-G2, Livingston Spring 2018 Cal Poly, Team S18-G2, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S18G2
5 名成员
创作了16篇指南
4条评论
Where do you buy a motherboard for the xz premium? thank you
Jonathan Storm - 回复
where can you buy a motherboard for the xz premium G8142?
dukeduane - 回复
If you know the name of the motherboard you can check on:
newegg.com
aliexpress.com
https://www.sony.com/electronics/support...
amazon.com
alibaba.com
Kristoffer Grundström -
Anyone know if you can replace the microphone on the XZ premium? I think it is attatched to the motherboard. Is it soldered on?
Tom M - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 34
总计 6,439
