简介
This is a replacement guide for the Sony Xperia XA1 speaker.
Before using this guide, be sure to check out the troubleshooting page to ensure the speaker needs to be replaced.
你所需要的
Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
Use a plastic opening tool to lift the battery connector.
Lift the flaps on both sides of the battery.
