跳转到主内容
Sony Xperia XA1 Rear Camera Replacement
你所需要的
  1. Sony Xperia XA1 Rear Camera Replacement, Phone Back Cover: 步骤 1 中的图像 1,3 Sony Xperia XA1 Rear Camera Replacement, Phone Back Cover: 步骤 1 中的图像 2,3 Sony Xperia XA1 Rear Camera Replacement, Phone Back Cover: 步骤 1 中的图像 3,3
    • Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
    • As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
    • Do not apply heat in one area for too long.
  2. Sony Xperia XA1 Rear Camera Replacement, Rear Camera: 步骤 2 中的图像 1,3 Sony Xperia XA1 Rear Camera Replacement, Rear Camera: 步骤 2 中的图像 2,3 Sony Xperia XA1 Rear Camera Replacement, Rear Camera: 步骤 2 中的图像 3,3
    • Use a Phillips #000 screwdriver to remove the three 3 mm screws near the top of the phone.
    • Use a spudger to gently pry the three tabs at the top of the phone.
  3. Sony Xperia XA1 Rear Camera Replacement: 步骤 3 中的图像 1,3 Sony Xperia XA1 Rear Camera Replacement: 步骤 3 中的图像 2,3 Sony Xperia XA1 Rear Camera Replacement: 步骤 3 中的图像 3,3
    • Gently pry at the tabs until the cover comes free and is able to be removed.
    • Pull the piece up and set it aside. No cables are attached to the back.
  4. Sony Xperia XA1 Rear Camera Replacement: 步骤 4 中的图像 1,3 Sony Xperia XA1 Rear Camera Replacement: 步骤 4 中的图像 2,3 Sony Xperia XA1 Rear Camera Replacement: 步骤 4 中的图像 3,3
    • Use an opening tool to release the back camera connector.
    • Gently pull the camera connector up to remove it.
    • Exercise caution when handling the rubber holder around the lens, as it can pop off easily.
结论
sebastianh034
于02/14/23注册
253 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 151
