跳转到主内容
Sony Xperia XA1 Battery Replacement
你所需要的
  1. Sony Xperia XA1 Battery Replacement, Phone Back Cover: 步骤 1 中的图像 1,3 Sony Xperia XA1 Battery Replacement, Phone Back Cover: 步骤 1 中的图像 2,3 Sony Xperia XA1 Battery Replacement, Phone Back Cover: 步骤 1 中的图像 3,3
    • Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
    • As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
    • Do not apply heat in one area for too long.
  2. Sony Xperia XA1 Battery Replacement, Battery: 步骤 2 中的图像 1,2 Sony Xperia XA1 Battery Replacement, Battery: 步骤 2 中的图像 2,2
    • Disconnect the battery from the motherboard using an opening tool or spudger.
  3. Sony Xperia XA1 Battery Replacement: 步骤 3 中的图像 1,3 Sony Xperia XA1 Battery Replacement: 步骤 3 中的图像 2,3 Sony Xperia XA1 Battery Replacement: 步骤 3 中的图像 3,3
    • Lift the black tabs on either side of the battery
  4. Sony Xperia XA1 Battery Replacement: 步骤 4 中的图像 1,3 Sony Xperia XA1 Battery Replacement: 步骤 4 中的图像 2,3 Sony Xperia XA1 Battery Replacement: 步骤 4 中的图像 3,3
    • Lift the pull tab at the bottom to unseat the battery.
    • After unseating the battery with the pull tab, lift it out of the case.
    • Use caution handling the battery. It is extremely delicate.
  5. Sony Xperia XA1 Battery Replacement: 步骤 5 中的图像 1,2 Sony Xperia XA1 Battery Replacement: 步骤 5 中的图像 2,2
    • Remove the battery entirely.
    • Do not dispose of your old battery in a regular trash can. Please bring your phone battery to a local home depot, best buy, or staples for safe disposal and recycling in the US and Canada. Other places in the world, please contact your local recycling centers.
结论
Lindsey Taysom
于02/14/23注册
205 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 46
总计 519
