跳转到主内容
Sony XAV-AX100 Display Replacement
你所需要的
  1. Sony XAV-AX100 Display Replacement, USB Cable: 步骤 1 中的图像 1,3 Sony XAV-AX100 Display Replacement, USB Cable: 步骤 1 中的图像 2,3 Sony XAV-AX100 Display Replacement, USB Cable: 步骤 1 中的图像 3,3
    • Place the device on a flat surface, upside down, so the bottom of the screen would be facing upwards.
    • Remove the ten 3.5mm Phillips #0 screws from the back plate.
  2. Sony XAV-AX100 Display Replacement: 步骤 2 中的图像 1,2 Sony XAV-AX100 Display Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool to remove the back plate.
    • Don't remove completely as there will still be cables connected.
  3. Sony XAV-AX100 Display Replacement: 步骤 3 中的图像 1,1
    • Disconnect the USB cable from the display board.
  4. Sony XAV-AX100 Display Replacement: 步骤 4 中的图像 1,1
    • Adjust the rubber holders that are keeping the USB cable still on the motherboard, so you can remove the cable entirely from the inner compartment.
    • The rubber holders are extremely sensitive to any applied force. Therefore, be careful while turning them around.
  5. Sony XAV-AX100 Display Replacement: 步骤 5 中的图像 1,3 Sony XAV-AX100 Display Replacement: 步骤 5 中的图像 2,3 Sony XAV-AX100 Display Replacement: 步骤 5 中的图像 3,3
    • Remove the 3.5mm Phillip #0 screw that secures the USB cable to the back panel.
    • Pull the USB cable off of the back plate.
  6. Sony XAV-AX100 Display Replacement, Motherboard: 步骤 6 中的图像 1,2 Sony XAV-AX100 Display Replacement, Motherboard: 步骤 6 中的图像 2,2
    • Disconnect the display power cable from the motherboard.
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
  7. Sony XAV-AX100 Display Replacement: 步骤 7 中的图像 1,3 Sony XAV-AX100 Display Replacement: 步骤 7 中的图像 2,3 Sony XAV-AX100 Display Replacement: 步骤 7 中的图像 3,3
    • Unscrew the four 3.5mm Phillips #0 screws from the motherboard.
    • Use a spudger to gently lift the motherboard up and out of the radio.
  8. Sony XAV-AX100 Display Replacement, Display: 步骤 8 中的图像 1,1
    • Remove the four 3.5mm Phillips #0 screws from the sides of the display.
  9. Sony XAV-AX100 Display Replacement: 步骤 9 中的图像 1,2 Sony XAV-AX100 Display Replacement: 步骤 9 中的图像 2,2
    • Remove two 3.5mm Phillips #0 screws from the back of the head unit.
结论
6等其他人完成本指南。
Abdulaziz Redha
于02/22/18注册
741 声望
创作了5篇指南
团队
USF Tampa, Team S1-G5, Cagle Spring 2018 USF Tampa, Team S1-G5, Cagle Spring 2018 的会员
USFT-CAGLE-S18S1G5
2 名成员
创作了5篇指南
3指南评论
Where do you get a replacement screen?
I need one for a xav 3005 db
Morten Hjorth-Johansen - 回复
Thank you very much for this great write up.
However after having performed it, if all you are doing is replacing the screen, then steps 1, 4, 5 and 7 are actually completely unnecessary . There is no need to remove the back panel or the motherboard.
but thank you nonetheless for having shown the way.
Robert Edwards - 回复
I need to get a replacement screen for a Sony xav 1500 any idea of a cheap place?
Abelardo M. - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 56
总计 5,864
