跳转到主内容
Sony Walkman NWZ-S764 LCD Screen Replacement
你所需要的
  1. Sony Walkman NWZ-S764 LCD Screen Replacement, Removing the back cover: 步骤 1 中的图像 1,3 Sony Walkman NWZ-S764 LCD Screen Replacement, Removing the back cover: 步骤 1 中的图像 2,3 Sony Walkman NWZ-S764 LCD Screen Replacement, Removing the back cover: 步骤 1 中的图像 3,3
    • Remove the two black 6.4mm Phillips screws from the back of the device.
  2. Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 2 中的图像 1,3 Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 2 中的图像 2,3 Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 2 中的图像 3,3
    • Using a plastic opening tool, work your way around the edges of the device, carefully prying off the front panel.
  3. Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 3 中的图像 1,2 Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 3 中的图像 2,2
    • Remove the two 2.8 mm phillips screws located on either side of the device near the top.
  4. Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 4 中的图像 1,2 Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 4 中的图像 2,2
    • Carefully pull the top piece away from the device.
  5. Sony Walkman NWZ-S764 LCD Screen Replacement, Removing the Bluetooth module: 步骤 5 中的图像 1,3 Sony Walkman NWZ-S764 LCD Screen Replacement, Removing the Bluetooth module: 步骤 5 中的图像 2,3 Sony Walkman NWZ-S764 LCD Screen Replacement, Removing the Bluetooth module: 步骤 5 中的图像 3,3
    • Use the flat end of the spudger to flip up the retaining flap for the bluetooth module.
    • Be sure to lift up on the retaining flap, and not the socket itself.
  6. Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 6 中的图像 1,3 Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 6 中的图像 2,3 Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 6 中的图像 3,3
    • Remove the two 1.8mm silver Phillips screws on the Bluetooth module.
    • Lift up on and remove the Bluetooth module.
    • The ribbon cable must first be removed in order to access the highlighted screw.
  7. Sony Walkman NWZ-S764 LCD Screen Replacement, Audio Port: 步骤 7 中的图像 1,3 Sony Walkman NWZ-S764 LCD Screen Replacement, Audio Port: 步骤 7 中的图像 2,3 Sony Walkman NWZ-S764 LCD Screen Replacement, Audio Port: 步骤 7 中的图像 3,3
    • Remove the two 2.8mm silver Phillips screws on the sides of the frame.
    • The two 2.8mm screws are on each side of the device.
    • Insert a plastic prying tool between the bottom of the case and the motherboard.
    • Pry up the assembly and lift it away from the case.
  8. Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 8 中的图像 1,3 Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 8 中的图像 2,3 Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 8 中的图像 3,3
    • Remove the yellow tape from the battery and volume control module.
    • Save tape for reassembly.
  9. Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 9 中的图像 1,3 Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 9 中的图像 2,3 Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 9 中的图像 3,3
    • Use a prying tool to pry under the volume control module.
    • This module is glued on, using too much force may damage or warp the module.
  10. Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 10 中的图像 1,3 Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 10 中的图像 2,3 Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 10 中的图像 3,3
    • Remove the tape from EMF shield and the LCD housing.
    • Lift up on the volume control ribbon.
  11. Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 11 中的图像 1,3 Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 11 中的图像 2,3 Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 11 中的图像 3,3
    • Insert a plastic opening tool under the battery and lift up to remove it.
    • The battery is glued on, too much force may damage the battery casing.
    • The battery is soldered to the motherboard, care should be taken to not place too much stress on the wires.
  12. Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 12 中的图像 1,3 Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 12 中的图像 2,3 Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 12 中的图像 3,3
    • Remove the black shielding tape from above the Hard Drive.
    • Peel the foam cover away from the hard drive.
    • Use a plastic opening tool to remove the EMF chip from the motherboard.
    • The hard drive is soldered onto the device. Be careful not to pull too hard on the hard drive.
  13. Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 13 中的图像 1,3 Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 13 中的图像 2,3 Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 13 中的图像 3,3
    • Remove the plastic bracket by pushing up with your thumb to expose the display connection.
  14. Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 14 中的图像 1,3 Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 14 中的图像 2,3 Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 14 中的图像 3,3
    • Use the flat end of a spudger to flip up the retaining flap on the audio jack module.
  15. Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 15 中的图像 1,2 Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 15 中的图像 2,2
    • Peel back the ribbon for the audio jack and remove the 1.8mm silver Phillips screw.
  16. Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 16 中的图像 1,3 Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 16 中的图像 2,3 Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 16 中的图像 3,3
    • Remove the mic casing by pushing up and in.
    • Remove the headphone jack and the bottom casing.
  17. Sony Walkman NWZ-S764 LCD Screen Replacement, Motherboard: 步骤 17 中的图像 1,2 Sony Walkman NWZ-S764 LCD Screen Replacement, Motherboard: 步骤 17 中的图像 2,2
    • Use the prying tool to remove the LCD ribbon wire.
  18. Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 18 中的图像 1,1
    • Lift up on the LCD ribbon and remove the two 1.8mm silver Phillips screws.
  19. Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 19 中的图像 1,3 Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 19 中的图像 2,3 Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 19 中的图像 3,3
    • Lift the motherboard away from the frame with your thumb to remove it from the device.
    • Pull the volume control module through the space in the frame.
    • If you are using the magnetic project pad or other magnetic surface to keep your screws, do not place the hard drive on or near the magnet.
  20. Sony Walkman NWZ-S764 LCD Screen Replacement, LCD Screen: 步骤 20 中的图像 1,2 Sony Walkman NWZ-S764 LCD Screen Replacement, LCD Screen: 步骤 20 中的图像 2,2
    • To remove the LCD display cover, first melt the glue with the iOpener tool.
    • For more detailed instructions on how to use the iOpener, see iOpener Instructions
  21. Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 21 中的图像 1,3 Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 21 中的图像 2,3 Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 21 中的图像 3,3
    • Carefully slide the iOpener wedge tool under the edge of the LCD display cover to separate it from the device.
    • Slide the wedge under all edges of the cover.
    • Once all of the glue has been broken, you can pull up on the cover to remove it.
    • The flat side of the spudger tool also works for this step
  22. Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 22 中的图像 1,3 Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 22 中的图像 2,3 Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 22 中的图像 3,3
    • Remove the two 1.8 mm Phillips screws from both sides of the frame.
  23. Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 23 中的图像 1,3 Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 23 中的图像 2,3 Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 23 中的图像 3,3
    • Use a strong pry tool to lift the metal brackets away from the device. You will need to bend the metal slightly to remove it from the dimples.
    • This step will require slight force to separate the frame. Do not bend the brackets too far so that they can be replaced later.
    • Once separated, pull the innermost frame containing the LCD display away from the brackets.
  24. Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 24 中的图像 1,3 Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 24 中的图像 2,3 Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 24 中的图像 3,3
    • Slide an opening pick under the LCD display to separate it from the rest of the device.
    • The pry tool also works for this step.
  25. Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 25 中的图像 1,2 Sony Walkman NWZ-S764 LCD Screen Replacement: 步骤 25 中的图像 2,2
    • Lift the LCD display off of the frame to remove it from the device.
结论
另外一个人完成了本指南。
Matthew Olson
于01/21/15注册
181 声望
撰写一个指南
团队
USF Tampa, Team 4-2, Brown Winter 2015 USF Tampa, Team 4-2, Brown Winter 2015 的会员
USFT-BROWN-W15S4G2
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 25
总计 2,299
