跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
If you have not fixed your problem through our Troubleshooting Guide, then you may have to replace your Hard Drive.
Hazards
Keep out of reach of children and pets.
DO NOT attempt to teardown or repair your device under the influence of drugs or alcohol.
DO NOT ingest any parts of the system.
Use the correct tools as stated in the tools section.
DO NOT touch any gold connectors on interior or exterior of the system.
Make sure system is unplugged before performing any maintenance on the system.
NOTICE
Make sure your replacement hard drive is a serial ATA hard drive (SATA). Any other hard drive will be incompatable.
  1. Set the computer display-side down.
    • Set the computer display-side down.
    • Unlock the battery by sliding the port-side latch to the 'unlock' position.
  2. On the opposite side of the battery, press the release latch and slide the battery away from the main body to remove.
    • On the opposite side of the battery, press the release latch and slide the battery away from the main body to remove.
  3. Ignore the removal of the heat sink and memory panels as depicted. They do not need to be removed for the completion of this guide.
    • Ignore the removal of the heat sink and memory panels as depicted. They do not need to be removed for the completion of this guide.
    • Remove the Torx security screw near the center of the battery-side edge.
  4. 基本电子产品工具包
    小工具包。却有无限可能。
    Shop Toolkits
    基本
    电子产品
    工具包
    Shop Toolkits
  5. Press the tabs on each side of the display-side of the keyboard with the flat edge of a spudger. Pull the keyboard toward the mouse pad and gently lift up.
    • Press the tabs on each side of the display-side of the keyboard with the flat edge of a spudger.
    • Pull the keyboard toward the mouse pad and gently lift up.
  6. The keyboard is still attached by ribbon cable, don't try to remove the keyboard entirely yet. Disconnect the ribbon cable by pressing the tabs on either side of the connector. Pull the cable out parallel to the connector.
    • The keyboard is still attached by ribbon cable, don't try to remove the keyboard entirely yet.
    • Disconnect the ribbon cable by pressing the tabs on either side of the connector. Pull the cable out parallel to the connector.
    • Remove the keyboard.
  7. Turn the laptop upside down.
    • Turn the laptop upside down.
    • Remove the three screws from the front mouse panel located on the bottom of the laptop.
    • Carefully flip the laptop back over. Remove three more screws from the top securing the panel. A ribbon cable will still be attached to the panel when you remove it.
  8. Lift the mouse assembly just enough to access the connecting ribbon cable. Lift the ribbon cable lock to remove the cable.
    • Lift the mouse assembly just enough to access the connecting ribbon cable.
    • Lift the ribbon cable lock to remove the cable.
    • Carefully remove the mouse panel assembly and set aside.
  9. This is where your hard drive would be located. The replacement must be a Serial ATA(SATA) hard drive
    • This is where your hard drive would be located. The replacement must be a Serial ATA(SATA) hard drive
    • Remove the four hard drive securing screws.
结论
17等其他人完成本指南。
Ashley Brooks
于2010年04月09日注册
276 信誉积分
创作了4篇指南
团队
Cal Poly, Team 25-89, Amido Spring 2010 Cal Poly, Team 25-89, Amido Spring 2010 的会员
CPSU-AMIDO-S10S25G89
4 名成员
创作了52篇指南
simple and perfect in every detail
francesco - 回复
添加评论
浏览统计数据:
过去的24小时: 3
过去的7天: 47
过去的30天: 190
总计 34,966
