你所需要的
Starting with the laptop top-down, locate and remove the twelve 1mm Phillips #0 screws securing the back cover to the main body of the computer.
Use the Plastic Opening Tool to gently remove the heat sink and fan assembly from the computer.
4等其他人完成本指南。
一条评论
Could you also maybe do a tutorial on Sony Vaio Fit 13? http://www.laptoppartstore.com/replace--... Any luck figuring out how the fan may be detached and re-attached to the heatsink? Also, I notice a very specific type of taping... where can one procure those?
Abhishek D - 回复
