跳转到主内容
Sony VAIO VPCEE26FX Keyboard Replacement
你所需要的
  1. Sony VAIO VPCEE26FX Keyboard Replacement, Battery: 步骤 1 中的图像 1,2 Sony VAIO VPCEE26FX Keyboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Ensure that the laptop is powered off before disconnecting the battery.
    • Flip the laptop over so the underside of the laptop is facing up.
  2. Sony VAIO VPCEE26FX Keyboard Replacement: 步骤 2 中的图像 1,2 Sony VAIO VPCEE26FX Keyboard Replacement: 步骤 2 中的图像 2,2
    • Slide the two tabs towards each other until the battery disconnects slightly from its position.
    • Carefully lift the battery out of its position away from the laptop.
    • The battery is not pictured here, since it is missing from this particular device.
  3. Sony VAIO VPCEE26FX Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,2 Sony VAIO VPCEE26FX Keyboard Replacement, Keyboard: 步骤 3 中的图像 2,2
    • Flip the laptop back over so it is face up.
    • Open up the laptop.
  4. Sony VAIO VPCEE26FX Keyboard Replacement: 步骤 4 中的图像 1,1
    • Using a plastic opening tool, pry along the seam between the keyboard and case to help in separating the two.
    • Continue to lift up gently using the plastic opening tool until the keyboard begins to separate from the case.
  5. Sony VAIO VPCEE26FX Keyboard Replacement: 步骤 5 中的图像 1,2 Sony VAIO VPCEE26FX Keyboard Replacement: 步骤 5 中的图像 2,2
    • Continue lifting up and moving down starting on the left side of the keyboard moving towards the right side of the computer.
  6. Sony VAIO VPCEE26FX Keyboard Replacement: 步骤 6 中的图像 1,2 Sony VAIO VPCEE26FX Keyboard Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Carefully tilt the top of the keyboard towards you ensuring the ribbon cable is not under too much tension.
    • Use a pair of tweezers to help remove the plastic adhesive film covering the adapter/port for the ribbon cable.
  7. Sony VAIO VPCEE26FX Keyboard Replacement: 步骤 7 中的图像 1,1
  8. Sony VAIO VPCEE26FX Keyboard Replacement: 步骤 8 中的图像 1,1
    • Lift the keyboard up and away from the computer.
结论
团队
UMass Dartmouth, Team S2-G3, Bailey Spring 2019 UMass Dartmouth, Team S2-G3, Bailey Spring 2019 的会员
UMASSD-BAILEY-S19S2G3
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 1,197
