本指南有最近更改,您可查看未经巡查的最新版本。
简介
If the Sony TCM-919 is not recording sound, this guide provides replacement solutions. Comprehensive device opening and dismantling up to microphone replacement will be covered.
你所需要的
Turn the device around so that the back cover if facing upward. Use your thumbs to press down firmly and then push the battery door cover open.
Remove any batteries.
Remove the 5, 5.95mm screws as indicated in the picture using the Phillips head screwdriver.
Look to the back of the top cover.
Desolder the two wires connected to the mircophone using the soldering station.
Gently remove the rubber top from the two plastic knobs that hold the microphone in place.
Remove the microphone by pulling up.
