简介
This guide will help users replace damaged or malfunctioning internal speakers on the Sony SRS-XB43 Bluetooth speaker. Please refer to the Troubleshooting Page before beginning the replacement guide steps. The two speakers being replaced are very magnetic so make sure that you keep track of all your metal screws and maintain a steady/firm hold on your tools.
你所需要的
Insert the metal spudger into the mesh's seam/opening located at the bottom of the speaker.
Begin applying pressure, prying along the run of the seam until the mesh cover begins to come loose.
Fully open the hinged mesh cover and pry it off the unit.
On the face plate of the speaker, locate the black ribbon cable plugged into the green circuit board to your right.
Grab the ribbon cable from its base and apply a light verticle force upwards to unplug it from the PCB.
另外一个人完成了本指南。
