跳转到主内容
Sony SRS-XB43 Battery Replacement
你所需要的
  1. Sony SRS-XB43 Battery Replacement, Faceplate: 步骤 1 中的图像 1,2 Sony SRS-XB43 Battery Replacement, Faceplate: 步骤 1 中的图像 2,2
    • Insert the metal spudger into the mesh's seam/opening located at the bottom of the speaker.
    • Begin applying pressure, prying along the run of the seam until the mesh cover begins to come loose.
    • Fully open the hinged mesh cover and pry it off the unit.
  2. Sony SRS-XB43 Battery Replacement: 步骤 2 中的图像 1,1
    • Turn the speaker so the back is facing you.
    • Remove the factory tamper seal below the speaker volume toggle to reveal a single screw.
    • Remove the single screw using a T8 Torx.
  3. Sony SRS-XB43 Battery Replacement: 步骤 3 中的图像 1,1
    • Remove all ten screws using a Phillips #1 screwdriver.
  4. Sony SRS-XB43 Battery Replacement: 步骤 4 中的图像 1,2 Sony SRS-XB43 Battery Replacement: 步骤 4 中的图像 2,2
    • Slowly lift the speaker face off of the housing unit.
    • Unplug the six wires connecting the faceplate to the motherboard.
  5. Sony SRS-XB43 Battery Replacement, Battery: 步骤 5 中的图像 1,2 Sony SRS-XB43 Battery Replacement, Battery: 步骤 5 中的图像 2,2
    • Orient the speaker's backplate so that the plastic chassis and internal electronics are facing upwards.
    • Remove the eight 10 mm screws securing the motherboard chassis to the backplate using a Phillips #1 screwdriver.
    • Grab the motherboard chassis and gently remove it from the backplate of the speaker.
  6. Sony SRS-XB43 Battery Replacement: 步骤 6 中的图像 1,3 Sony SRS-XB43 Battery Replacement: 步骤 6 中的图像 2,3 Sony SRS-XB43 Battery Replacement: 步骤 6 中的图像 3,3
    • Orient the motherboard chassis so that the side with the six buttons is facedown on the table and the opposite side is visible to you.
    • Disconnect the seven-prong cable (the one with red, yellow, and black wires) plugged into the motherboard by prying on its edge/extruding lip with a spudger.
  7. Sony SRS-XB43 Battery Replacement: 步骤 7 中的图像 1,2 Sony SRS-XB43 Battery Replacement: 步骤 7 中的图像 2,2
    • Orient the plastic chassis so that the port housing PCB is facing upward.
    • Remove the plastic black film covering the battery, leaving the blue battery exposed.
  8. Sony SRS-XB43 Battery Replacement: 步骤 8 中的图像 1,2 Sony SRS-XB43 Battery Replacement: 步骤 8 中的图像 2,2
    • Lightly pull the seven-prong cable upwards until the battery is angled in such a way that you can get a proper grip on both sides with your fingers.
    • Using your fingers, pull upwards until the battery is removed from its enclosure.
    • Do not use a spudger or other flat tools to pry in between the seam of the battery and the battery compartment, as it is possible to damage the battery.
结论
2等其他人完成本指南。
Luke Escobar
于10/28/22注册
159 声望
撰写一个指南
团队
UMass Dartmouth, Team 3-5, Botvin Fall 2022 UMass Dartmouth, Team 3-5, Botvin Fall 2022 的会员
UMASSD-BOTVIN-F22S3G5
4 名成员
创作了5篇指南
一条评论
So, where can we buy a new battery to use these instructions for replacing it ?
Doubletap - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 33
过去 30 天: 166
总计 2,295
