简介
Identification
This lens can be identified by the markings “E 4.5-6.3/55-210 OSS” in addition to the model/serial number sticker.
Additional Links
你所需要的
Gently disconnect 3 cables from ZIP connector.
The two wider connectors open from the cable side, the thinner connector opens from the back side.
Remove 3 screws.
Pull lens out of external encasement.
Maneuver the telescope sensor so that it unmates from the slot in the internal lens body
Carefully feed the OSS/AF motor wire through the slot.
Remove 3 screws from the aperture end of the telescoping mechanism.
Lift lens to reveal and remove 3 brass/nylon nuts.
Remove 3 screws from the slide guides on the aperture end of the lens.
Remove 3 black nylon slide washers from the lens encasement.
Remove the OSS/AF mechanism.
Gently pull the cable up and out from the lens encasement groove.
Remove Kapton tape from aperture motor connector.
Disconnect aperture connector.
Remove 2 screws from aperture ring.
Remove aperture mechanism.
Disconnect 3 cables.
Remove 3 screws
Gently separate the OSS mechanism.
3等其他人完成本指南。
2条评论
why did you need to dissasemble this lens. this lens looks similar to my 55mm lens which no longer focuses and the camera doesn’t recognize the lense anymore.
I need to know maddly, how can I have a reposition of the 6 spring there are on the first lense.
Is there any way?
If not, can you tell me specificcaly the size and the strength?
