跳转到主内容
Sony PS1100 Needle Cartridge Replacement
  1. Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge from the player: 步骤 1 中的图像 1,3 Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge from the player: 步骤 1 中的图像 2,3 Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge from the player: 步骤 1 中的图像 3,3
    • Place the Arm of the record player into the latch to ensure that it does not move during the needle replacement.
    • The arm must be fully locked into place
  2. Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge: 步骤 2 中的图像 1,1
    • Firmly grip both sides of the cartridge with your thumb and index fingers.
    • CAREFULLY pull the entire cartridge so that it slides out towards the front of the arm holding the needle.
  3. Sony PS1100 Needle Cartridge Replacement, Insert new needle cartridge: 步骤 3 中的图像 1,2 Sony PS1100 Needle Cartridge Replacement, Insert new needle cartridge: 步骤 3 中的图像 2,2
    • Using the New cartridge (Sony VL-30G) gently slide into the arm of the record player. It will click into place when inserted properly.
    • Be careful not to touch the needle when inserting the cartridge or else you risk breaking the new one.
  4. Sony PS1100 Needle Cartridge Replacement, Test the new needle Cartridge: 步骤 4 中的图像 1,1
    • Once the needle clicks into place, test the record player to ensure that the needle works properly.
结论
另外一个人完成了本指南。
L Cis
于10/10/14注册
110 声望
撰写一个指南
团队
USF Tampa, Team 1-8, Donnelly Fall 2014 USF Tampa, Team 1-8, Donnelly Fall 2014 的会员
USFT-DONNELLY-F14S1G8
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 34
总计 4,692
