跳转到主内容
Sony H.ear on 3 Right Speaker Housing Disassembly
你所需要的
  1. Sony H.ear on 3 Right Speaker Housing Disassembly, Extend the Right Speaker: 步骤 1 中的图像 1,2 Sony H.ear on 3 Right Speaker Housing Disassembly, Extend the Right Speaker: 步骤 1 中的图像 2,2
    • Extend the Right cup and fold the Left cup away via the headband .
    • This will help protect the other ear pad while you work on this one.
  2. Sony H.ear on 3 Right Speaker Housing Disassembly, Unclip the Right Ear Pad: 步骤 2 中的图像 1,3 Sony H.ear on 3 Right Speaker Housing Disassembly, Unclip the Right Ear Pad: 步骤 2 中的图像 2,3 Sony H.ear on 3 Right Speaker Housing Disassembly, Unclip the Right Ear Pad: 步骤 2 中的图像 3,3
    • The pad is attached by 6 clips in a hexagonal pattern, shown by the arrows.
    • Starting from the top, insert an opening pick in between where the cup leather meets the plastic casing, push it in firmly, then twist it until you disengage the top clip.
    • Try not to damage or peel off the leather while doing this. It helps if you pry towards the speaker housing, not the leather cup.
    • Work round the back side, poking the pick in and twisting to disengage further clips until you can gently pull the cup away.
    • When re-assembling, make sure that the stitching line on the ear pad is facing the bottom.
  3. Sony H.ear on 3 Right Speaker Housing Disassembly, Unscrew the casing on the Right Speaker: 步骤 3 中的图像 1,1
    • Check that you are on the Right Speaker using the indicator on the headband.
    • Use a JIS #000 screwdriver to remove the 5 6mm screws holding the Right Speaker casing in place.
    • Gently lift the casing apart like a book from the bottom.
    • Do not lift it completely away as the touchpad is still connected by a delicate ribbon cable.
    • When re-assembling, make sure the touchpad ribbon cable isn't pinched by the casing.
  4. Sony H.ear on 3 Right Speaker Housing Disassembly, Locate the battery and touchpad connectors: 步骤 5 中的图像 1,3 Sony H.ear on 3 Right Speaker Housing Disassembly, Locate the battery and touchpad connectors: 步骤 5 中的图像 2,3 Sony H.ear on 3 Right Speaker Housing Disassembly, Locate the battery and touchpad connectors: 步骤 5 中的图像 3,3
    • Gently peel back the foam tape with a spudger and unstick it from the two cables underneath.
    • The battery and headband cable held in place against the PCB and internal enclosure of the Right Speaker with foam tape. The ZIF connector the touchpad is to the side and not covered in tape.
    • Headband cable connector (under foam tape)
    • Battery connector (under foam tape)
    • ZIF connector for touchpad
    • Foam tape
    • Using tweezers, gently grab and pull the smaller connector up from the circuit board to disconnect the battery.
    • Be extra careful to make sure you don't puncture the battery with the tweezers.
    • Using a spudger, gently flip up the latch on the ZIF connector on the circuit board connecting the touchpad.
    • Gently lift the ribbon cable away.
  5. Sony H.ear on 3 Right Speaker Housing Disassembly, Remove the Touchpad: 步骤 8 中的图像 1,1
    • You can now safely remove the touchpad from the Right Speaker.
结论
Before re-installing the cups, test your headphones to make sure they turn on and work in a basic way.
Caius Nocturne
于07/12/21注册
2,066 声望
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 289
