跳转到主内容
Sony H.ear On 2 Motherboard Replacement
你所需要的
  1. Sony H.ear On 2 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,2 Sony H.ear On 2 Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,2
    • Start on the left side by using the plastic opening tool in the crease between the ear cup and plastic. Gently apply pressure until it separates.
    • Do not force any parts off as the plastic holders may snap off if too much pressure is applied.
  2. Sony H.ear On 2 Motherboard Replacement: 步骤 2 中的图像 1,2 Sony H.ear On 2 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Use the JIS #00 Screwdriver to remove the 2 6.4mm screws holding in the motherboard.
  3. Sony H.ear On 2 Motherboard Replacement: 步骤 3 中的图像 1,3 Sony H.ear On 2 Motherboard Replacement: 步骤 3 中的图像 2,3 Sony H.ear On 2 Motherboard Replacement: 步骤 3 中的图像 3,3
    • De-solder all 18 wire-connections on the motherboard.
    • Record wire positions on board for proper connections when re-soldering the replacement board.
    • Do not overheat joints while de-soldering to prevent board damage.
    • Please see 如何焊接和拆焊 for help on soldering and desoldering connections.
  4. Sony H.ear On 2 Motherboard Replacement: 步骤 4 中的图像 1,2 Sony H.ear On 2 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Disconnect the white ribbon cable by gently tugging on the white connector while holding the motherboard carefully in place.
  5. Sony H.ear On 2 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Gently remove the old motherboard from the bracket assembly and replace and resolder motherboard.
结论
Michael Long
于04/15/19注册
131 声望
撰写一个指南
团队
Cal Poly, Team S9-G11, Maness Spring 2019 Cal Poly, Team S9-G11, Maness Spring 2019 的会员
CPSU-MANESS-S19S9G11
5 名成员
创作了16篇指南
一条评论
where can i find a replacement motherboard for these headphones?
MTL - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 1,512
