跳转到主内容
Sony H.ear On 2 Microphone Replacement
你所需要的
  1. Sony H.ear On 2 Microphone Replacement, Ear Cup: 步骤 1 中的图像 1,2 Sony H.ear On 2 Microphone Replacement, Ear Cup: 步骤 1 中的图像 2,2
    • Start by inserting the iFixit plastic opening tool in the crease between the hard plastic and the ear cup, and then gently apply pressure until it separates. You may need to repeat the process on back until it is completely separate.
    • This may take a considerable amount of pressure, but do not force it.
  2. Sony H.ear On 2 Microphone Replacement: 步骤 2 中的图像 1,2 Sony H.ear On 2 Microphone Replacement: 步骤 2 中的图像 2,2
    • Use the JIS #00 Screwdriver to remove the five 6.4 mm screws holding the back plastic cover in place.
    • Then, turn the ear cup over and carefully lift the plastic cap off to reveal the internal components of the left ear cup.
    • This same process can be repeated on the right ear cup as well. Be aware the right cup is connected to the rest of the headphones via ribbon cable.
  3. Sony H.ear On 2 Microphone Replacement, Noise Cancelling Microphone: 步骤 3 中的图像 1,3 Sony H.ear On 2 Microphone Replacement, Noise Cancelling Microphone: 步骤 3 中的图像 2,3 Sony H.ear On 2 Microphone Replacement, Noise Cancelling Microphone: 步骤 3 中的图像 3,3
    • Use the iFixit plastic opening tool to lift the microphone out of its housing
    • Use gentle pressure to prevent damaging small wire connections
  4. Sony H.ear On 2 Microphone Replacement: 步骤 4 中的图像 1,2 Sony H.ear On 2 Microphone Replacement: 步骤 4 中的图像 2,2
    • Use soldering iron to desolder microphone wires from motherboard
    • Please see How to Solder and Desolder Connections before you attempt to use the soldering iron.
    • Note: Do not overheat joints while de-soldering to prevent board damage
结论
3等其他人完成本指南。
Justin Ramirez
于04/15/19注册
127 声望
撰写一个指南
团队
Cal Poly, Team S9-G11, Maness Spring 2019 Cal Poly, Team S9-G11, Maness Spring 2019 的会员
CPSU-MANESS-S19S9G11
5 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 33
总计 2,081
