跳转到主内容
Sony H.ear On 2 Bluetooth Transceiver Replacement
你所需要的
  1. Sony H.ear On 2 Bluetooth Transceiver Replacement, Ear Cup: 步骤 1 中的图像 1,2 Sony H.ear On 2 Bluetooth Transceiver Replacement, Ear Cup: 步骤 1 中的图像 2,2
    • Start by inserting the iFixit plastic opening tool in the crease between the hard plastic and the ear cup, and then gently apply pressure until it separates. You may need to repeat the process on back until it is completely separate.
    • This may take a considerable amount of pressure, but do not force it.
  2. Sony H.ear On 2 Bluetooth Transceiver Replacement: 步骤 2 中的图像 1,2 Sony H.ear On 2 Bluetooth Transceiver Replacement: 步骤 2 中的图像 2,2
    • Use the JIS #00 Screwdriver to remove the five 6.4 mm screws holding the back plastic cover in place.
    • Then, turn the ear cup over and carefully lift the plastic cap off to reveal the internal components of the left ear cup.
    • This same process can be repeated on the right ear cup as well. Be aware the right cup is connected to the rest of the headphones via ribbon cable.
  3. Sony H.ear On 2 Bluetooth Transceiver Replacement, Bluetooth Transceiver: 步骤 3 中的图像 1,2 Sony H.ear On 2 Bluetooth Transceiver Replacement, Bluetooth Transceiver: 步骤 3 中的图像 2,2
    • Then, turn the ear cup over and carefully lift the plastic cover off to reveal the internal components of the right ear cup.
    • Unlike the right ear cup, there is no ribbon cable directly connecting the rest of the headphones to the outer cup.
  4. Sony H.ear On 2 Bluetooth Transceiver Replacement: 步骤 4 中的图像 1,3 Sony H.ear On 2 Bluetooth Transceiver Replacement: 步骤 4 中的图像 2,3 Sony H.ear On 2 Bluetooth Transceiver Replacement: 步骤 4 中的图像 3,3
    • Using the JIS #00 screwdriver, remove the two 6.4 mm screws holding the NFC chip in place over the motherboard.
    • Once the screws are removed, gently turn over the board to the left to expose the soldered connection points.
  5. Sony H.ear On 2 Bluetooth Transceiver Replacement: 步骤 5 中的图像 1,2 Sony H.ear On 2 Bluetooth Transceiver Replacement: 步骤 5 中的图像 2,2
    • Using a soldering iron, carefully de-solder the two connection points on the NFC chip.
    • Once the solder has completely melted, carefully separate the wires and the NFC chip itself.
    • Please see How to Solder and Desolder Connections before you attempt to use the soldering iron.
结论
Peter Van Ness
于04/15/19注册
147 声望
撰写一个指南
团队
Cal Poly, Team S9-G11, Maness Spring 2019 Cal Poly, Team S9-G11, Maness Spring 2019 的会员
CPSU-MANESS-S19S9G11
5 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 20
总计 1,341
