本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide will show you how to access and replace the main keypad of the phone. Use this guide if the keypad needs to be cleaned or repaired. You can also remove the keypad, decorate it, and have your phone stand apart from the crowd.
你所需要的
Remove plastic cover with a plastic opening tool.
It is easiest to begin at the SD card slot and alternate prying the cover on opposite sides.
The cover will not come off all the way, but will only pry loose up to the camera. This is because there are additional screws that need to be removed.
另外一个人完成了本指南。
